Question about Kenwood KDC-X811
Kdc-x811 i replaced the ribbon cable because it was torn. put it all back together and now it only opens and closes. no light, controls, nothing. screen is dead. what did i do? how can i fix it?
5 Suggested Answers
Eagleeyes
  • 199 Answers
SOURCE: Flip bit not working KDC-7090R
hi its going to be the flexi that connects the panel to the main pcb. you can buy a repair kit @ www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 27, 2008
tech48
  • 624 Answers
SOURCE: Power problem with my KDC-M7024
The part number for that cable is
J84-0154-05
This other cable going from the other display to the main board should also be replaced at the same time.
J84-0153-05
You can verify the part number by looking right on the cable, it is on the very end of the cable on the part that overlaps the connector the cable plugs into.
Only places i know that sell them are authorized kenwood servie centers. There should be one in your area.
please give me a "fixya" if this helps.
Thanks
Posted on Jun 18, 2008
SOURCE: Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Posted on Jan 18, 2009
Wolfman304
  • 720 Answers
SOURCE: kenwood excelon kdc-x815 display screen no power
If you can turn the unit ON/OFF or operate the station presets on your faceplate, then the faceplate is OK.
It's possible the fault lies in the display resistors, inside the unit itself.
Check out my tutorial, which may help explain:
http://www.fixya.com/support/r16293427-repair_no_display_kenwood_faceplate
Cheers,
Scott
Posted on Feb 01, 2013
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
The radio opens with lights and lsights go out and immediately closes. Keeps opening and closing with no sounds. After doing so for a bout a year... radio came on. However did not come back on when I...
It sounds like it could be a bad ribbon cable. There are two ribbon cables in the deck, so it could be either one, or both. There is also a face position sensor lever inside the deck that goes bad.
Jul 22, 2011 | Kenwood KDC-MP822 CD Player
After putting faceplate back on it will not close
it sound like you have a broken ribbon cable. it is a part that needs to be replaced professionally.
Aug 19, 2009 | Kenwood KDC-9017 CD Player
Maytag quiet series 200 dishwasher won't start
I had a similar problem. Turn off the power to the dishwasher. Open the door and remove the screws on the back that holds the door together. Now, locate the black control module and remove the cover. Look down at the bottom left of the control module and you should see a ribbon cable. This is the cable that connects the door keypad to the control module. Unplug the ribbon cable and the plug it back in. On my unit the ribbon cable was not making good contact and only half of the keypad was operational,
Hope This Helps !!
James D.
Jul 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Ps2 disk tray wont open, power light is on, eject light is off
if the ribbon cable that goes to the lens came out its gota go back it. has a plastic tab on the top that lifts up and down to lock it in place....
If its the eject/reset button the ribbon might not be in all the way
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Dec 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
J84-0154-05
J84-0153-05
Thanks
Nov 21, 2007 | Kenwood KDC-M7024 CD Player
Kenwood KDC-X811 Logo
57 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
