Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
No blue green yellow like in football peach color flags thrown peach color grass is blue green purple color is black etc etc
These problems started when I was trying to turn on dvd,unpuged dvd, still tress blue greeen, ocean surrounding florida is black whats going on?
    Problem Solver:
  • 18 Answers
Are you using a component video connection (3 wires for the video, colored red, green, and blue)? It sounds as though you are, but correct me if you are using a different connection as the steps will be different. If so, ensure that they are all connected. You can also unplug one at a time while watching the picture. If the colors DON'T change when unplugging any individual wire, then check that wire from end to end looking for cuts/corrosion/etc... If necessary, replace the cable. Also make sure that they're plugged in to the right jacks, they should be color coded. NOTE: there is a red jack for the video AND for the audio. Check carefully that these aren't mixed up.
Posted on Nov 08, 2013
  • Kathy lovstad
    Kathy lovstad Nov 27, 2017
    Thank you , I was just wondering if you had to earn those colored flags from your achievements from playing golf crash
SOURCE:
skotkolr
  • 558 Answers
SOURCE: TV displays only two colors yellow and purple
you can only have the component video hooked into the component video if you try to down grade (used s video or the yellow cable to connect video you you will get funny colors you need to change the output of the dvd player to one of those not progressive scan on the component side. hpe this helps
Posted on May 28, 2008
SOURCE: Panasonic TC-P42U1 plasma. Lost it's vivid colors
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
Posted on Jul 23, 2010
welcomejee
  • 10594 Answers
SOURCE: my panasonic tv has started
Replace convergence ICs in tv by local tv repairman to fix tv problem as picture become very bad due to convergence chips failure.
Posted on Oct 13, 2010
eagle338
  • 4889 Answers
SOURCE: Panasonic TH-50PZ77U Plasma is 3
The fact that the picture is coming back to normal and then going back to the black and white mode, suggests that it is a capacitor problem. I suspect the location of the capacitors to be the main board, tuner board or the sustain boards. A problem of this extent means that you can identify them visually(cracked, bulged tops, or tiny holes at the top near the X cut). Replacing it depends on your prior experience in repairing electronics. High voltage electronics are not be messed with. The several thousand volts of resident electronic charge can cause permanent disability/death if not handled carefully.
Posted on Nov 07, 2010
eagle338
  • 4889 Answers
SOURCE: 2 year old flatscreen, the
There seems to be a problem with the RGB amplifier on the DG board of the set. Replacing that should resolve the issue but its gonna need pretty good electronics and soldering skills as the pins of the IC have to be de-soldered from the board and the new IC has to be soldered in. Would you like to do it yourself?
Posted on Nov 21, 2010
No audio out
find dvd mother boar pre amplifier signal & jumper with output.how to find tuch audio port tress the audio L & R or " output transistor,ic in pre audio tress.
May 30, 2012 | Televison & Video
I need to know the speaker wire colors for a 1994 toyota 4runner limited
According to the book it is: right speaker-1 light green with black 2 blue with red 3 light green with black 4 blue with black...left speaker:1 light green with blue 2 light greeen 3 light green with yellow. This out the book, if you dont under stand because wiring diagrams are hard to read, get back to me and i'll see if i can send you a picture of it ok.
Aug 20, 2011 | 1994 Toyota 4Runner
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
Surround sound speakers distort when playing blue ray dvd.
what you have to do is turn off your system then turn it on until you get 2 beeps. then go through the on screen instr.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
Wharfedale LCD37F1080P and external surround sound
  1. hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
Aug 09, 2008 | Televison & Video
Black pages
I would try and turn the unit off, unpug, wait. Replug, switch on and try again. This sometimes resets errors. Post back if no go lilacgerry xxx
Feb 06, 2008 | Brother MFC 6800 All-In-One Laser Printer
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
