Question about Crosley CW6000 Front Load Washer
Brake is stuck
My crosleys inner basket is stuck. this has happened before and i had it fixed. now with three small children i cannot afford professional assistance. I just need to know how to release the brake and check the thrush bearing and or hub. please help
  • FelixMendeld Nov 28, 2008
    The brake in my Crosley washer sometimes sticks. What needs to be replaced or adjusted?
    New Friend:
I can forcibly turn by drum in one direction but the brake is obviously engaging. Frankly I'm inclined to disengage it entirely. How do I get the front panel off?
Posted on Jan 28, 2013
    Sergeant:
    Champion:
  • 219 Answers
Iwould feel around the top of splash guard and see if there is a obstruction.If not then cheak if there is a nail or screw stuck in the inner tub that maybe stoping it from spinning.If not you may need a thrust bearing kit.cheak the pully and see if you can turn the tub manualy if see thrust bearing if not tub bearing kit needed call for a repair man GOOD LUCK :)
Posted on May 07, 2009
How do I remove a stuck inner basket on a Whrilpool Washer Model GSQ9364HQ0, Serial CK0946360 ?
You are going to have to lay the machine down and work from the bottom to pull the transmission and shaft out of the drum.
May 01, 2015 | Washing Machines
I just asked a question about a stuck inner basket on a Whirlpool Washing Machine. What happened to my question ?
what makes u say its stuck? is it just not spinning, or wash agitating? do u hear noise? might have bad bearings or drum spline is damaged
May 01, 2015 | Whirlpool Washing Machines
Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
Our Crosley washing machine (Model # CW5000W) will not spin all the water out of the clothes and is making a bad noise while it spins.
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
May 04, 2011 | Crosley Washing Machines
In the middel of the wash it stops and the creen haas a fon it?
Tilt the unit back & shine a light through the clear plastic of the outer basket & see if you see clothing stuck in between the outer basket & inner basket. The floating basket should lift up & down if you grab the inner basket from the inside & lift up.
Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It throws a code oL it means over load and there's nothing it it but water so how can it be reset please
Tilt the unit back & shine a flash light through the clear inner basket & see if there is any clothing stuck in between the inner basket & outer basket. Open the lid & lift up on the inner basket It should move up & down.
Remove the drum on a top loaded washing machine
odds on something being between the tub and basket is very small.  noise probably coming from brake/clutch or transmission just to name a few possibilities...
Jul 24, 2010 | Whirlpool Washing Machines
Theres a banging noise when the machine is spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
------------------------ The problem is the brake. The odd time what happens is moisture gets on thebrake rotor and the squealing is heard when the brake stator is applied to stop the tub from spinning. This moisture, may drip down from the tub onto the brake rotor which could indicate a leaky tub seal. If you can't see any dripping when you fill the tub with water, don't worry about the tub seal. Many times than not the brake is just going sour on it's own.
Sometimes you can fix the squealing by cleaning the rotor and stator with a light sandpaper, such as emery/sand cloth. If that doesn't work you will need to replace the brake stator and rotor. If you need to replace them replace both parts together, don't just change the stator without also replacing the rotor, or vice versa. And here's a bonus tip: the brake spring exerts 200 pounds of force. If you try to remove the six 5/16" screws without using this brake removal tool, serious injury can/could happen!! The splined part in the middle of the brake needs to be greased really good before putting the brake back on!
The drive/motor pulley on these washers is plastic. It can wear and start to slip on the drive belt, might be best to replace the belt at the same time if you find a worn/ground up motor pulley. The motor pulley presses onto the motor shaft, cutting or breaking the old one is common when changing it.
noises also comes from bad wheel bearing would make.]
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Mar 14, 2009 | Washing Machines
Inner basket scrapes on bottom of liner tub during spinn cycle
It sounds like the basket drive block is worn. If it looks like the basket drive block has slid down the brake & drive tube (I believe you're calling it the spindle), it's definitely worn out. When this part is in place it sits on top of the brake & drive tube and won't allow the basket to go lower. To replace this, remove the cabinet to gain access to the the inner basket which you will have to remove. On the top of the brake & drive tube you will see 2 small tabs. Align these with the cutouts on the basket drive block. Mount the drum back on top, and tighten the spanner nut. Reassemble the cabinet and you should be good to go.
Let me know if you need more assistance.
Feb 21, 2009 | Whirlpool LSR5132PQ Top Load Washer
Crosley CW6000 Front Load Washer Logo
228 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
