The items to check are
Waste gate on the turbo
Please email me the turbo model #
Example: G3
EGR valve (stuck open or not moving freely) / need to remove carbon in EGR valve
(if equipped in emission state / country)
Clean EGR passage tube.
REMOVE ALL CARBON with WD-40 or PB Blaster
Check for vacuum leaks.
YOU MUST replace EGR base mount gasket.
Inspect timing belt tensioner.
Jumped timing / belt
Check for burn / loose rubber particle on the bottom of the timing belt cover.
Recheck timing marks / dots and make sure it's line up correctly.
You should change the water pump and T-belt at the same time.
Check the service record for the last water pump change.
Spin the water pump and check for free movement and leak.
After everything are check out then open the valve cover to do a valve adjustment.
You should do valve adjustment every year or 12-18,000 miles.
Monitor for oil leaks from rear main seal,front seal and val
ve cover.
Check for white smoke at the tailpipe after 10-15 minutes of warm up time to rule out head gasket damage.
check for cross mix of oil and coolant.
TDI should go well over 200,000 miles before major over-haul.
