Question about Kirby G5 Bagged Upright Vacuum
Removal of Outer Bag for washing
I want to soap up the outer bag on my G5. How do I remove it from the hard plastic foot that connects the bag to the vac head suction nozzle. It has a strap on it like a zip tie...how do i remove that to clean in there
  • 357 Answers
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEANING-THE-KIRBY-VACUUM-OUTER-CLOTH-BAG_W0QQugidZ10000000003719865
It should be helpful. :0)
Marci
Posted on Oct 16, 2007
SOURCE:
How to get dog smell out of xl2600hh
Denise,
You need to do a bag wash of your outer bag. You will need to take the bag dock off if you have one of those on your vacuum or take off the "U" shaped clip if you do not have a bag dock and then pull the bag off of the connector assembly. You will also need to remove the plastic part at the bottom of the bag, you can usually use a flat blade screwdriver to pop that plastic part off. Turn your bag inside out and if you have a canister vacuum, vacuum the bag off the best that you can. If you do not have a canister vacuum, you could hose the bag off with a spray nozzle to get rid of any excess dirt. You then want to soak the bag in hot water with the Oreck Enzyme Odor Eater or with a good quality soap. I work at an Oreck store on weekends and we do this frequently. The Enzyme odor eater works great and leaves a nice smell behind in the bag fibers. We usually soak it overnight and then rinse the bag real well and then let it hang dry. If it is a nice sunny day, you can hang it outside and it should dry in 3 to 4 hours. Then you just reverse the process to put everything back together. Hope this helps!
Aug 11, 2015 | Vacuums
How do I replace the OUTER bag on my Oreck XL2200?
Depends on whether you have a bag dock or not. If you have a bag dock, squeeze the inside part where it hinges and pull off the outer part, then spread the inner part and pull off of the handle tube. Then you can pull the outer bag off of the same handle tube connection and then disconnect from the bottom. Installation is just the reverse of taking it off. If you do not have a bag dock, there is a "U" shaped clip that goes over the top of the bag connection on the handle tube. Use a flat blade screwdriver to pry up on the clip and pull it off. You can then pull your bag off the handle tube and disconnect at the bottom and replace your bag. Hope this helps!
Oct 05, 2014 | Oreck XL2200RS lightweight upright vacuum...
Outer Oreck xl bag is full of dirt
Make sure that your bag is pushed all the way past the lip on the connector tube and that the "U" shaped part of the plastic assembly is in it's slot behind that lip, or it will not seal properly and you will get dust into the outer bag.
Mar 21, 2014 | Oreck XL2200 Bagged Upright Vacuum
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Kirby Ultimate G Diamond edition vacuum. We were told you can wash the outer bag. Is that true? How do you remove the bag to do this?
Twist the bag emptor left to remove it from the upright then your need a sharp narrow pointy object (like a metal dental pick cost $1 in most stores) push it under the plastic band around the rubber on the bottom of the cloth bag roll it across and take off the plastic tie once off pull the rubber bottom part of the bag emptor take out the inner plastic tube and zip the bag put in the washer by itself and wash with soap and softner and let hang dry you can also wash the inner plastic tube with hot water and fabuloso I recondition kirbys and do it all the time.
Jul 07, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Having a terrible time keeping the bag attached during use. I am tired of cleaning the inside of the cloth zippered bag. I am using the correct Oreck vaccum bags, and using the metal clip that holds the...
I would Recommend getting a docking system. its $20 and takes place of the metal clip and ensures that the paper bag and outer bag both stay in place and to ensure no leakage.
Sep 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I would really like to wash the outer bag of my vacuum, but I have a problem. I can remove the outer bag from the vacuum, but the plastic 'frame' that is inside the outer bag is sewn to the bag. So what...
you can wash the bag. However you cannot wash the bag in the wash machine. What you will want to do is look for the screw or depending on the model, untwist the cap down on the rod next to the machine. that entire pole section will come off of the unit below with the bag there.
I recommend if it is warm outside to use the garden hose to spray it and scrub inside the bag with a scrub brush and some dish soap.
I usually throw them into the laundry sink and let soak, scrubbing with soap and water.
To dry the bag, a hairdryer or hang to dry before putting the piece back onto the machine.
Good luck.
Mark
Nov 12, 2010 | Oreck XL2000 Bagged Upright Vacuum
I need to remove the outer bag from my Kirby upright. The inner bag was not attached and there is mung everywhere.
In order to remove the outer jacket from your Kirby do the following.
Detach the top bag clip from the handle support. There is a plastic piece, just below the outer jacket, called the mini emptor. Turn it to the right to remove the entire bag assembly. Removing the outer jacket is dificult and even harder to put back on so this is what I would do.
Unzip the outer jacket as you were going to change the bag. Remove the paper bag. You will then see a long black tube, that has a 90 degree elbow at the top. That elbow is attached to the inside of the bag with a snap type strap. Remove the strap, then you will be able to move the tube, while you clean out the inside of the bag. When finished put everything back where it was.
Apr 28, 2010 | Kirby G4 Bagged Upright Vacuum
I bought a Kirby Diamond Ultimate G on ebay and I'm happy with it but the outside bag smells strongly of cigarette smoke. How do I clean the bag so I don't smell smoke when I vacuum?
Greetings from GoVacuum,
Actually you can even wash this outer bag in the washing machine under a gentle cycle. It's best however not to put this in the dryer, but instead let it air dry completely before using it again in the vacuum cleaner.
You can remove the outer bag by first unclipping the top of the bag from the handle. If you look up at the top where the vacuum bag and the handle meet, on teh backside you can push the arm that the bag connects up into, allowing the bag to fall down. Then you'll need to remove the boot, or the mini emptor part at the bottom of the bag.
Standing on the side of the vacuum cleaner, with the bag right in front of you, grab the plastic boot part of the bag with both hands, and rotate the boot away from the vacuum cleaner, or counter clockwise until it is released from the vacuum cleaner. It may take some elbow grease, but this boot will come off I promise.
Once you have the outer bag off of the vacuum completely, make sure to remove the inner disposable bag first before washing the outer bag. If you'd rather not throw this into the washing machine, you may also just let the outer bag sit in a sink or tub full of hot water and simple green, then take it outside and use the garden hose to rinse it off. Again VERY IMPORTANT do NOT use the vacuum again until the bag has completely dried.
If you have any questions, or would like some clarification, please email me at [email protected] and I'll be happy to answer any further questions or concerns.
If this was helpful, please rate this repair tip by clicking the 4 Thumbs Up iconds in the top right hand corner of this Solution.
Thanks so much,
Chris Jones
GoVacuum.com
Mar 10, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum bag busted
Greetings from GoVacuum.com,
Yes, you certainly can take off the outer bag of your Oreck and wash it in the washing machine. You DO NOT however want to put the bag through the dryer!!!!! Just hang the bag outside, and let it air dry. It is important to make sure that the bag is 100% completely dry before you use the machine again. If the bag is wet, it will cause dirt to turn to mud in the bag, and probably cause a foul odor when you use the bag.
There are 2 different types of bag systems with Oreck vacuums. The one pictured below is the older style that uses a metal clamp to hold the bag in place. The newer docking system, will be a white plastic clamp that holds the outer bag in place. They both will be removed the same way however. Simply take a screwdriver and pry off the clamp;
Once you have removed this clamp, simply pull the outer bag off. Once it has been washed, and the bag is 100% completely dry, put the outer bag back over the bag housing as far as it will go. When you put the clamp back on, it is imperative that the clamp go behind the plastic ridges, to ensure that it is tightly fastened. If the clamp is not put on correctly, this will cause the inner paper bag to fall off during vacuuming. Make sure that the clamp is in the right position when putting the bag back;
If you have any further questions, please feel free to email them to me. I really enjoy sharing my knowledge an passion about vacuum cleaner, and vacuum repairs. We do stock all Oreck parts, so if you need any parts, please let me know.
Chris Jones
GoVacuum.com
[email protected]
Oct 15, 2008 | Oreck XL2200 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
689 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
