Blows the breaker when plugged in
Possible short in the mains circuit. You need to remove the back panel and check the main wire to the board. Sometimes the surge protector which is within the board could be short due to a high surge voltage, you could use a meter to see if the AC input is short which can confirm this fault. If not the main board could be faulty. Disconnect one circuit at a time , one connector at a time to solve this case by elimination of each circuit and confirm when the short finally is seen.
