Question about NEC ViVid Office 2020 Printer
Vivid2020 wont duplex
Have tried pcl and ps driver. duplex option extended memory bypass tray and extra feed tray are all enabled in the printer configuration. print to both sides of paper is available and enabled. will not print duplex. will copy duplex fine. i have installed several of these machines and have never had this issue before.
What is it wanting me to do when it says "install duplex unit"?
A duplex unit allows you to automatically print double sided jobs. It sounds like a duplex unit is an option on your printer. If it is asking you to install a duplex unit, it is either configured for duplex printing i.e in your printer setup, duplex printing is enabled or, your driver has two sided printing enabled as its default.
Hope this helps.
Jan 22, 2011 | Office Equipment & Supplies
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Aug 06, 2010 | HP LaserJet color laser printer
When printing large powerpoint presentations half way through it will give a pcl xl error missingdata readimage
too much data or not enough memory in your printer to support the job.
Also possibly corrupted data in your powerpoint doc.
if you are using PCL version of the driver, download and setup the PS (PostScript) driver from HP.
There are conflicts with printing PDF/Powerpoint docs using PCL driver.
let us know if this helps. Another thing you can try if possible, convert the Powerpoint into a PDF file and then try printing, but select "Print as Image" in the Advanced section of the print options.
Feb 03, 2010 | HP Color LaserJet 4600n Printer
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
Doubled-up duplex printing
Try printing from several applications, and see if the problem follows one spesific app. It might be an application problem. If the problem remains, try printing with another driver. Both PCL and PS. Try to avoid HP's universal drivers. Try printing direct to the printer and via the printserver. If the problems still remains, perform a Cold Reset. Still error, replace the system board.
Jul 27, 2009 | HP Office Equipment & Supplies
I need to know how to choose a duplex print option for this printer.
when choosing the printer go to printing preferences and you will see the option for duplex if the printer has that option.
Apr 30, 2009 | Office Equipment & Supplies
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Option to Print on both sides does not appear
Check your driver. If you are using a recent version of "HP Universal Printing PS" driver, the duplex option is in the finishing tab.
Feb 10, 2009 | HP LaserJet 4650 Color Printer Manual...
Duplex printing problem
do you have to replese driver of printer for IR6000
Feb 10, 2009 | Canon imageRUNNER 5000 Copier
2 sided printing problem
What driver did you download? The PS driver is much less capable and I am wondering if thats what you downloaded.
I am using the PCL driver and the selections are 1 sided, 2 sided long edge , 2 sided short edge.
Unless you are runnung CAD, you really should be running a PCL driver.
Maybe I am misunderstand what you are telling me also.
If you have the PCL driver and thats still a problem let me know and I will forward all I can find.
Feb 22, 2008 | Xerox WorkCentre Pro 123/128 Printer
NEC ViVid Office 2020 Printer Logo
23 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
