Question about KitchenAid KGSI901PBS Gas Kitchen Range
Gas range (oven)won't lite (gas broiler works fine)
Broiler works perfect as does the range top. Intermittent problem....I turn the range on...the fans spin up (convect)...then I hear the gas relay click open and the the piezo ignitors go off 3 times...click..click..click....then I hear the gas valve click off....it waits about a minute and then tries again....sometimes it lights, sometimes it doesn't...I have taken the bottom of the range apart and and cleaned the piezo ignitor like it's a spark plug...took some sandpaper to the element and the ground and cleaned it off..sometimes it works, sometimes not...just tried it now and the broiler lite 3/3 times...stove 1/3. Where is the model number of it (looks like the one in the pic but I want to make *sure*). Sounds like an igniter problem to me...how does one dissasemble it to fix? Can I buy the part online? Thanks for any advice you can offer. Tony (Ottawa, Canada)
  • 473 Answers
Sounds like an ignitor problem or possibly a dirty orifice. Model #'s are usually on the frame behind the bottom drawer.
Posted on Oct 05, 2007
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Amana gas oven will not stay lit
i'm having the same thing happen to me however the broiler works fine.
Nov 17, 2008 | Amana ACF3355 Gas Kitchen Range
Oven will not light
ck your light bulb . and ck with meter see if you geting any voltidge
Feb 05, 2008 | Amana AGR5735QDS Gas Kitchen Range
KitchenAid KGSI901PBS Gas Kitchen Range Logo
443 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
