My printers keeps losing its connection to my laptop and Ipad and I have to keep reinstalling every time I want to use them together.
I gave a cannon Pixma 712. I installed it and it worked great. I could print from both my laptop and Ipad. A couple weeks later, I tried to print, and the Ipad would not locate it, and the laptop could not find it either. I uninstalled everything, reinstalled all drivers, and again it worked. A couple days later...same thing, I pad cant find it, and laptop cant print to it. I try to just update drivers and it gives errors. I have to totally uninstall the program and reinstall it. Then it works right away when I do it, but not again after that. Please advise what I can do. I have checked the firmware for the printer, and it is fine. All my other printers work fine, and the network it ok. The printer will scan and copy, just cant connect to computers.
Re: My printers keeps losing its connection to my laptop...
It may be losing its IP address. Check the DHCP address affectation of your router. And leave your printer constantly connected to the router. You should also let your printer get the IP address automatically upon booting.
a quick remedy is to get a memory card reader. remove it from the camera then insert the card into the reader's slot. its fast and reliable. camera software and drivers get messed up really bad sometimes. its the drivers that gets screwed recognizing the camera when its plugged in.
oh by the way, have you tried plugging the USB plug to another port on your pc?
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device. In this case we can close in on three solutions 1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
In your case, you can still try some methods to fix it. Just follow below steps.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode. iPad Air
1. Turn off your iPad Air, press and hold the Home button.
2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
1. Connect your iPad to your computer or laptop and open iTunes.
2. While your device is connected, force to restart it.
3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
As for unlocking iPad, there are several ways you can resort to. Just follow one of them as below shows.
iPad mini/iPad pro
You can enter the recovery mode in iTunes and restore password on your disabled iPad. Just follow below steps to do that.
iPad mini/iPad pro
For more methods, check: How to Unlock iPad?
You can follow below steps to do that. There takes iPad as an instance.
iPad mini/iPad pro
If you forgot iPad password, there still are several methods to unlock iPad. Here take one of them as an instance.
iPad mini/iPad pro
There is only one way I know but you will lose everything up until the last time you backed it up ok turn it off after its off connect the cable to pc or laptop first make sure ipad still of ok then press and hold the home button don,t let go now plug in charge cable keep holding home button until you get the connect to iTunes symbol on the ipad if iTunes doesn,t open then click on it you should now see iTunes has detected it in recovery mode just click on restore or restore and update
Did you forget the password? If so, follow below steps to unlock it.
iPad mini/iPad pro
Did you forget passcode to get into iPhone? If so, you can try below method to unlock it.
iPad mini/iPad pro
Sounds like you have troubleshot all of the physical connections. Have your replaced/updated the driver? Go to HP's support website and see if there's an updated driver for your printer and operating system, i.e., mac, vista, xp, etc. My printer came with two discs and I accidently installed the wrong driver. I had similar problems. Hope this helps.
