Supersonic SC-91JB 9-inch Android 4.1 Capacitive Touch Tablet PC Logo
r
robin marshall Posted on Nov 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do battery hazard sysbol comes up?
When turn on battery hazard symbol comes up .
Keith Methot
Level 2:
  • Expert 112 Answers
  • Posted on Nov 07, 2013
Keith Methot
Expert
Level 2:
Answers
112
Questions
Helped
43325
Points
226
The battery is becoming faulty and will need to be sent in for service. A hard reset MAY help.
10" contixo kids tablet shows battery 100% charged but will not turn on. What do I do?
Please remove battery and place the + and - side according to the battery-located instructions or symbols provided. If the tablet does not work after that, please use a different pair of batteries to attempt to turn on the tablet.
Thank you.
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
2answers
I have a android jellybean 4.2 tablet when you put it on charge comes up with charge symbol then when you try turn it on it comes up with the android symbol filling up with jelly beans then lights word for...
Check by replacing the battery. If battery is weak [in terms of current storing capacity], the phone will show; as the battery is fully charged, but, when the software starts to load, the voltage of the battery will go very low than normal. If so, the fault you indicates here can happen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
2helpful
Why does the battery level icon show only a "lightning strike" symbol?
Lightning Strike Symbol means that the battery is charging.
If it is shown even when it is not charging then your charging circuit needs to repaired. Just replace the charging IC not a very high cost. Might cost around 5-10USD.
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Top Supersonic Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Supersonic Tablet and eReader Expert? Answer questions, earn points and help others
