FixYa.com
Tags:
Uniden Bearcat Pro PC68LTW 40-Channels Base CB Radio
I can't pick up anything...
posted by maddog6 on Oct 04, 2007
I have a Uniden Bearcat Pro PC68LTW with a 5ft metal whip i have power to the cb and everything is hooked up properly however i can't pick up anything except for a weather channel and can not hardly hear that even!?!?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 04, 2007
Not Rated (0)
Shuttle83
Rank:Wiz Wiz
Rating: 84%, 600 votes
Hello even though everything is connected properly, have you checked for standing waves on the antenna to radio connection? Also you may have to perform a sensitivity test on the unit. The problem is you need a RF generator for that. Set you RF generator to the frequency that is equal to the CBs middle frequency and modulate the CW with 1KHz at 50% modulation, tune to the middle of the CB band on the radio and set the output of the RF generator to .1uv and loosely couple the signal to the CB antenna with a loop of wire. Your CB should be picking up a 1KHz tone gradually turn the power level down and when the tone cuts off that level is cutoff level, then increase the level until you can hear the tone again when the tone cuts on that value is the sensitivity of the unit. Compare the measured value to the value in the owners documentation. if the sensitivity is low this could denot a problem in the RF/IF section of the CB.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these CB Radios problems?
CB Radios
CB RADIO UNIDEN WASHINGTON...
Hi, i have a Uniden Washington... Answer This...
CB Radios
becker radio/tape code
becker europa radio/tape block... Answer This...
CB Radios
transmite does not recieve
talks out good, transmites,... Answer This...
CB Radios
Radio
Set clock radio Answer This...
Uniden Bearcat Pro PC68LTW 40-Channels Base...
I can recieve but i cannot...
I can recieve tranmissions but... Answer This...
Repair Service
Find CB Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
