Question about E-Machines eMachines Desktop PC
E machine t2482
Monitor says no signail
    Problem Solver:
Check pins some time one of the pins on cable can push through or come out if one is missing it will not work quick way to check is if possible connect to another running tower.
Posted on Oct 05, 2007
Make sure the plug is plugged into the right spot. If this computer has a video card you would plug it in towards the bottom of the case but if it has integrated graphics with no video card then it would plug in closer to the top close to where the mouse and keyboard plugs are. If it does have a video card these can go bad so you may need a new one. They only take a few minutes to install and aren't too expensive unless you do a lot of gaming. You can get a decent card for around $40 to $50.
SOURCE:
Turn signail flasing very fast tail light don't work
Turn signal bulb is burned out most likely cause.
Mar 01, 2013 | 2004 Chevrolet Cavalier
Necesito los driver de emachines t2482
Hola, la chaqueta es conveniente descargar los controladores de aqu?.
Estos archivos deben extraerse antes de la instalaci?n.
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1509
Sep 08, 2011 | E-Machines T2482 PC Desktop
Need a picture of a e-machine motherboard for wiring diagram
See if the link below helps any with your wiring dilema.
Just scroll down and follow along.
http://www.build-your-own-computer.net/computer-wiring.html
Jun 07, 2010 | E-Machines T2482 PC Desktop
How do I get the AC97 Audio to work on Ubuntu?
ok your have a cd that came with your computer
you have to load it frist hope it will work
if you dont ccome right email me no [email protected]
Dec 14, 2009 | E-Machines T2482 PC Desktop
I have a T2482 pc, I am not sure which pins the
See if you can find the motherboard manufacturer and circuit board #. Do a search either for manufacturer or motherboard number. They should have the pinouts. They might have a diagram of what color wire plugs where.
Nov 03, 2009 | E-Machines T2482 PC Desktop
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Need diagram of t2482 e-machine tower
a diagram of the front of the computer is in the emachines user guide. you can download it from this link below http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf the diagram is on page 9. Chapter 1
Sep 11, 2009 | E-Machines (T2824) PC Desktop
My EMachines T2482 will not power up properly. The fan comes on, but the monitor remains in the sleep mode, and as far as I can tell, no POST is occurring. The ring around the power button remains dark. It...
Did you remove the CMOS battery and move the jumper on the systemboard to clear the CMOS? After a few minutes or so, put the jumper back and power on the machine. If it powers on fine, you can turn it off and put the CMOS battery back in.
Jun 06, 2009 | E-Machines eMachines Desktop PC
E machine t2482
Try changeing the RAM and if that dosent work try the processor
Jun 02, 2009 | E-Machines eMachines Desktop PC
Emachines T2482
Could be a video card failure or a cable problem. This could also happen because the motherboard failed if you have integrated video. Unfortunately your going to have a tech onsite to repair the issue. That is, unless you want to install your own video card which would probably fix the issue.
Jul 08, 2008 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
157 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
