Question about Sharp AL 1631 Copier
My copier flashes H then 4
I don't have a manual and am lokking for on but till then my copier flashes H then 4 and won't work
  • goldy52 Dec 10, 2007
    I Have AL1540CS and have exactly the same problem. Flashes H then 4.
  • linus24 Nov 24, 2008
    Sharp AL 1271
    Novelist:
  • 208 Answers
Try this, it should reset your machine.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time
Posted on Dec 20, 2007
  • 62 Answers
This problem is a fuser heating error one of two problems lamp is bad or the breaker in the fuser is bad.
Posted on Oct 09, 2007
  • 69 Answers
Hi im jules_09.its not a error code there s just an open door or a piece of paper stock in fuser unit if not cheeck you bypass tray it because thoose parts have sensors that indicate the trouble
Posted on Oct 04, 2007
Dishwasher lights flash half way through program
you will have to consult your owners manual
Jun 07, 2012 | Dishwashers
My print activity says something is being deleted but it won't delete
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted......
It will not show that message again.
Good Luck!!!!
Sep 26, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Doors wont lock. Windows won't work. Car thinks the door is locked because when I open the hood alarm goes off. Security light is flashing when doors are closed. Locks don't engage when driving...
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door. Could be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released. It could also be the body control module.
Aug 28, 2011 | 2003 Volkswagen Jetta TDI
I need to replace the back up light fuse... i do not have a owners manual
Helm.Com --- buy owners manual
Check all the fuses for now, till you
receive the manual
If you don't know where it is,you don't know
it is blown & if it is, replacing it won't fix a thing
Aug 09, 2011 | 2003 Lincoln Navigator
Don't know how to change paper size on LED screen
what is the model
but at model **3 **6
you can try this:
1- press key drawer & copy together for more 5 seconds
2- when all lamps flashing press {drawer} till the drawer you want to setup
3- then press {copy} till the {other} lamp flashing - "the last one" see the number on the LED screen
4- change the LED screen number "13" to "20" for LT size
Jun 28, 2011 | Toshiba Office Equipment & Supplies
I need the manual on how to set the radio stations
thttp://www.retrevo.com/support/Blaupunkt-MP3000-Car-Receivers-manual/id/550ci556/t/2/
here is your manual....just click the red download button the fill in your email addy and the code and it will download for you. It is a pdf file so if it wont open you need adobe acrobat reader...d/l that and try again...
for the clock keep pressing disp till you see clock 12----then rotate the dial to select 12 or 24 hr format----then press disp to display clock adjust-------then press muts/sens to flash the hour-----rotate dial to desired hour-----press mute/sens to flash min-----rotate dial for correct min----press disp to complete the time set.
don't forget to give testimonial and the votes 4 thumbs up if I helped.
May 29, 2011 | Blaupunkt MP3000 CD Player
Toshiba e-studio 120 copier. Won%u2019t work. Flashing H, flashing 4.
hi H4 is a fusing unit problem check your heater for a poor contact or open thermal fuse
Oct 24, 2010 | Toshiba Office Equipment & Supplies
I am lokking for a manual for the f2280 hp photosmart all in one printer scanner and copier
you can download from here :
http://h10032.www1.hp.com/ctg/Manual/c01438223.pdf
please rate me and vote for my solution
Aug 14, 2010 | Office Equipment & Supplies
Cant open or format 4gb kingston flash
Right click on My Computer, choose Manage
A Computer Management console will appear.
On the left lokk for Disk Management and click on it.
Wait a little until the values on the right loads.
Now locate the Kingston drive, right click it and format it.
Don;t forget to rate this answer if it helps
Jul 20, 2009 | Electronics - Others
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Sharp AL 1631 Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
