Question about Comtrend Modems
CT-560 How to hook up, I think I hooked it up right but it doesnt work. help please
0 characters
1 Points
Internet will not go through my comtrend CT-5072T modem
Need a bit more background on this.
Did you just go out and buy this device and hook it up to the phone line ?
Are you using ADSL line Filters ?
Did you ring your internet service provider to guide you through setting up the account settings in the modem ?
How are you connecting to the device to your P.C ?
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
I have a rca dcm315 cable modem a I can connect to the internet through a usb cable but not a ethernet cable. All I'm tring to do is hook up 2 computers to the internet and I just can't seem to get the...
When switching from USB to Ethernet (Or opposite) you have to unplug it, then hook up the Ethernet cable and plug it back in.
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Apr 01, 2010 | RCA Cable Modem DCM315R (11603540)
Lost dial tone and phone service
Your phone line might be connected to Telephone 1 not 2. That could be the reason why you are not getting a dial tone.
Nov 22, 2009 | Arris Touchstone 450a (CM450) Modem
How to hook up two computers to one comtrend ct-5611t modem
Get yourself a router to connect modem to computers.
Nov 13, 2009 | Modems
Cant hook up xbox 360 to internet
does this help it sounds like you are puting your cable in to the 360 and the modem you wont have a internet ligth on untill you try to connect the 360 to go live you must reset the modem
Jan 23, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
Ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
Mar 01, 2008 | Comtrend CT 300 (CT-300) Modem
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Protron HDTV Cable hook up
if u want true hdtv buy a samsung 1080P LCD
Nov 11, 2007 | Intel VOICE D41JCTLSEURO PFU CT LSGS Comm...
Modems Logo
Top Comtrend Modems Experts
Sudeep Chatterjee
Sudeep Chatterjee
Brett Duxbury
Brett Duxbury
Are you a Comtrend Modem Expert? Answer questions, earn points and help others
