Question about HP OfficeJet 7310 All-In-One InkJet Printer
Print Cartridge Holder Failure
The print cartridge holder is broken and I am seeking a replacemnet. I need a source for this part.
  • DickVW Oct 12, 2007
    As was my experience in the past, HP will not allow me to purchase the repair part.  HP will repair the printer for $279.00 or will discount a replacement printer at a discounted price.This is the second time this item has failed. The first time was under warranty and the printer was replaced with a refurbished unit.
I had the same problem and just ordered one directly from HP. I called 800-474-6836 gave them my model number and serial number and they set me right up. Give them a try. Hiram896
Posted on Oct 09, 2007
SOURCE:
Is there instructions for replacing the MP730 printhead (QY6-0064-000 ) anywhere?
Remove Ink Cartridges Lift grey lever to the right side of the cartridge holder to the up position.
The print head should lift out nicely. You may need to squeeze sides of the cartridge holder slightly to the center in order to clear the outer print head assembly.
May 03, 2011 | Office Equipment & Supplies
I cannot change the cartridges as yhe holder seems to be stuck
Welcome to FixYa!
Note: When removing and inserting back the print cartridges, you need to use a small amount of force because of its safety locks. Just be careful not use excessive force, it might damage your printer.
If your printer has Two Cartridge System with no latches, here's a proper way to remove and insert the print cartridge. Please refer to the image below.
1. Press down the tip of the print cartridge and pull it away. You will hear a "click/tick" sound while pressing it downwards.
2. Make sure to remove the protective cover of the print cartridge.
3. Slide in the new print cartridge in its holder.
4. Lock it by doing the figure #4 in the picture below. You will hear a "click/tick" sound which indicates that it is locked.
If your printer has Two Cartridge Systems with latches, here's how to do it.
1. Pull up the latch. You will hear a "click/tick" sound.
2. Pull away the print cartridge.
3. Make sure to remove the protective cover of the print cartridge.
4. Slide in the new print cartridge.
5. Close the latch. You will hear a "click/tick" sound.
Thank you for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP DeskJet 940c InkJet Printer
How do I get the cartridge out to replace with new one???
The steps of replacing cartridge with a new one.
1) First You keep the printer power on. Open the printer cover - you will find the cartridges holder will come in proper place (the position varies printer to printer) so that you can easily remove the old cartridge.
2) Press gently the upper front portion of the cartridge you want to remove out of the printer holder - you will find it will be unlocked - just remove the cartridge carefully. (in some printer there is a cover on top of the cartridge holder which you can open to perform the step 2.
3) Unpack the new cartridge.
4) Don't forget to remove the plastic tape from the cartridge head (Ex.in HP, Lexmark cartridges etc).
5) Look the printer holder and look to the cartridge - you can easily decide the position of the cartridge in the holder.
6) Gently and carefully  put the cartridge in the holder - press the upper portion of the cartridge from front side - the cartridge will be locked autometically in the holder.
7) Put the printer cover in proper place.
8) Print Now - it will print test page first. Now print as usual.
I hope the solution is helpful to you. Thanks for using fixya.com.
Jun 23, 2010 | Office Equipment & Supplies
The print cartidge is missing
Please note the printer make and model and visit any computer shop - disclose the model name there they will give you the perfect cartridge. If you know how to fit the cartridge then well but if you don't then unpack the cartridges and please remove the plastic tape from the cartridge head or it will not work, open printer cover up - notice the empty cartridge holder in the printer, there you notice black and color cartridge holder. Look to the cartridge and holder you will understand the position of the cartridge to fit, now push the lower portion of any cartridge to the holder and give a very low pressure on the top (backward pressure to fit the in the holder). Same way you fit the next cartridge. Close the printer cover down. Print any document - it will definitely print.
Jun 09, 2010 | HP DeskJet F380 All-In-One Printer
Black ink cartridge holder not working , can not print with black ink cartridge holder, when i use the colored ink holder printer works ok
The problem you are describing is with the black ( BC-10 ) print head and not with the printer.
1. Check your black ink tank and be sure it is not dry.
2. Run the printer through one DEEP cleaning cycle and see if that improves the print.
If your black ink tank is full, and the deep cleaning cycle produces no improvement, you will need to replace the BC-10 print head.
Mar 11, 2010 | Canon BJC 85 InkJet Printer
Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Apr 11, 2009 | Canon MultiPASS C530 InkJet Printer
Color cartridge errors
The only reason for getting error "PU IN CARTRIDGE" is that the cartridge is not installed correctly. Follow these steps to reinstall the cartridge which will resolve the problem:
Note: The same step can be performed for error "photo ink in use" but if this does not resolve the issue, you can try and change the cartridge.
Feb 11, 2009 | Canon MultiPASS C530 InkJet Printer
Installed black print cartridge will not print now?
nope, there should be no tape on the cartridge. This is preventing the ink from coming out.
Jul 30, 2008 | Lexmark X6170 All-In-One InkJet Printer
Black ink won't print
Any tape/plastic left on the contact points on the cartridge, or any dirt on the contact points on the cartridge or cartridge holder? Will your old cartridge work, except poor print due to empty of ink? If so your new cartridge may be broken.
See if you can try a cartridge known to work in your printer and also try your cartridge in a printer similar to yours to eliminate source of error.
Mar 13, 2008 | HP DeskJet 3930 InkJet Printer
DELL AIO 922- All in one- Printer won't print
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Sep 06, 2007 | Dell 922 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
83 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
