Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows XP Pro "System Restore" not working
I have numerous Restore Points but every time I want to do a Restore to an earlier day it comes up "Not able to restore your computer...blah, blah, blah" I've checked the usual places to make sure its up AND running.Please help! And THANK YOU for your time & talent. Danny G.
  • 3 Answers
After repeated attempts to try and get the System Restore to restore to an earlier date but always failing I relented to try what I had been advised to do but didnt agree with at the time, which was to uninstall the Norton Symantic End Point Antivirus protection. Which cured the system Restore problem needless to say I have a different Antivirus protection installed now.
Posted on Jun 17, 2009
    Scholar:
  • 151 Answers
You can choose the first most restore point which you have not created but it is created by the system itself. Remember the first most restore point not any one of yours.. All the best
Posted on Oct 05, 2007
System Restore fails if any program is upodated either manually of automatically
  • incorn Oct 05, 2007
    I have found that if there are any updates either manually or automatic, the System Restore fails.
  • 883 Answers
There is something wrong with the registry, both current and prior (all of the restores did not work, right?). do a reg scan using one of the free scanners available like at zdnet.com. once scanned and repaired, disable restore mode (assuming none worked-you will lose all of them) and then run check disk, then defrag. then enable restore mode again and full shut down. now turn on and test the restore point you just made (run restore). if it does not work, you may need to re-install windows. if it does work, remember to repeat above process at least once every 3 months. too many restore points eat up hard drive space.
Posted on Oct 04, 2007
My pc keeps shutting down and starting up after checking the files its windows xp home
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Apr 15, 2013 | Computers & Internet
Tip
System Restore
Use System Restore to Undo Changes if Problems Occur
Windows XP Professional makes it easier to resolve problems if they occur in your system. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won’t lose changes made to these files. Windows XP creates “restore points” every day, as well as at the time of significant system events (such as when an application or driver is installed). You can also create and name your own restore points at any time. Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select a restore point and Windows XP undoes any system changes made since that time.
When you run System Restore, a calendar is displayed to help you find restore points. If you don't use your computer every day, some days might not have any restore points. If you use your computer frequently, you might have restore points almost every day, and some days might have several restore points.
To create a Restore Point
1. Access the System Restore Wizard through Help and Support Center. (Click Start, and then click Help and Support. Click Performance and Maintenance, click Using System Restore to undo changes, and then click Run the System Restore Wizard.
2. Click Create a restore point, and then click Next.
3. In the Restore point description box, type a name to identify this restore point. System Restore automatically adds to this name the date and time that this Restore Point is created.
  • To finish creating this restore point, click Create.
  • To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
  • To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date when the restore point was created from the calendar in the Select a Restore Point screen. All of the restore points that were created on the selected date are listed by name in the list box to the right of the calendar.
To set advanced restore options
1. Open Backup. (Click Start, goto to All Programs, point to Accessories, point to System Tools, and then click Backup.) The Backup Utility Wizard starts by default, unless it is disabled.
2. Click the Advanced Mode button in the Backup Utility Wizard.
3. Click the Restore and Manage Media menu and select the files to restore.
4. Click the Start Restore button.
5. On the Confirm Restore dialog box, click Advanced.
6. Set the advanced restore options you want, and then click OK. See the Notes section for a description of each option.
on Dec 01, 2009 | Computers & Internet
Acer
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. if this hails to fix the problem http://support.microsoft.com/kb/307545/ restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download you could select the option start with command prompt you should be in DOS mode black screen type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive you should have no input while chkdsk utility is in progress any input might further damage your hard drive
Apr 06, 2013 | Acer Aspire One Zg5
Locked up on restart... How do I solve this mess????
Sony's Vaio line of laptop and desktop computers ship with the latest version of Windows installed. Even the best designed Vaio computer can sometimes malfunction, occasionally in connection with an error in Windows. Boot your Vaio computer in Windows' "Safe Mode" to disable potential problem-causing drivers and programs to help you troubleshoot and fix your Sony computer.
Windows XP Press the power button on the Sony Vaio computer, typically found in the top right corner of the laptop's keyboard panel or on the desktop's tower. If your computer is already on, press "Start" in the lower left corner of Windows XP and press "Turn off computer." A new window will appear. Press the green "Restart" icon. Hold down the F8 key on your Sony Vaio's keyboard as soon as your computer's screen goes dark. A new window, labeled "Windows Advanced Options," will appear. Choose one of the Safe Mode options listed. "Safe Mode" loads the minimal amount of drivers, while "Safe Mode with Networking" also loads your networking preferences. Press "OK." b> Windows 7 Press the Sony Vaio computer's power button if it's off, or restart the computer. Click "Start" in the lower left corner of Windows 7 and choose "Shut Down." A new window will appear. Push "Restart." Press and hold your computer's F8 key. A menu called "Advanced Boot Options" will launch on the screen once the restarting process is complete. Choose "Safe Mode" or "Safe Mode with Networking" and press "OK."
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 15, 2013 | Computers & Internet
Disk read error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 12, 2013 | Compaq Hewlett Packard nc6220 PC Notebook
Windows xp will not load on MS-N011
Step 1:
Des Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 05, 2013 | Computers & Internet
When i insert the plug to my laptop, the sounds from the speakers disappeared so i thought it's alright but no sounds are coming from both buds.what should i do? it still has a warranty but i want to fix...
If the computer was playing sound earlier but now now, we can try doing system restore (if it is windows XP, Vista or Windows 7),
Procedure for XP:
Click on start
Click on Programs / all programs
Click on Accessories
Click on System Tools
Click on System restore
Choose restore your computer to a previous time
Choose a bold date, couple of days previously when you know your computer was working fine and follow on screen instructions
If you do not have a hardware problem, this should solve by loading the old settings.
Procedure for Vista / Windows 7:
Click on Start / orb / pearl
Type system restore and follow onscreen instructions to restore your computer to earlier time.
Jan 02, 2011 | Skull Candy Lowrider Professional...
How to repair Windo XP Pro. SP-3. Midea Plaire is also not working.
Hi Good day!!! Here are some ways to repair your winXP
Repair Windows XP Files with System Restore
1. Save your work and close all open programs. Click Start, then Control Panel, then Performance and Maintenance. On the left side of the screen, click "System Restore."
2. Select "Restore my computer to an earlier time." Click Next.
3. Click a date with a bolded number in the calendar on the left. Make sure this date is at least 1 day in the past. On the right side of the window, select a restore point. Click "Next" twice to restore your system.
Repair Windows XP Files With the Installation CD
1. Back up all of your user files onto removable media such as CDs or DVDs. Find your Windows XP installation or recovery CD, and insert it into the optical drive that your computer can boot from. Click Start, then Turn Off Computer, then Restart to reboot your computer. When the "Press any key to boot from CD" message appears, press a key on your keyboard. Press "Enter" to start Windows XP setup, and press F8 to accept the licensing agreement.
2. Select the path of your Windows installation and press "R" to begin repairing it.
3. Follow the instructions provided by the Windows XP repair program and finish the reinstallation. Go to the Microsoft website and download Service Pack 2 from their website, then visit Windows Update to install Windows XP Service Pack 3, critical updates and Internet Explorer 7.
Thank you for using FixYa
Don't forget to vote thanks!!
Nov 05, 2010 | Computers & Internet
Cannot perform system restore
since you said earlier it was working it seems some program has disabled the system restore feature. follow the steps below .
right click on my computer icon on desktop > select properties > system restore tab > uncheck "turn on system restore on all drives" if it is checked.
hope this solves your problem.
Aug 10, 2009 | Microsoft Windows XP Professional SP3 Full...
KDS Valiant no image on on screen
first of all try to start your laptop in safemode
1 start laptop
2 continously press F8 key
3 when you see menyu select "start windows in safe mode"
if your computer starts with same mode and you see the desktop
then you just have to restore your xp with earlier system restore check point
and if you dont see desktop in safe mode also then you must have to install win xp again
steps for restore windows xp
1 start
2 programs
3 accassories
4 system tools
5 system restore
6 chose restore system to earlier time
then select any earlier date in calender at which computer is working properly
and click restore
it restores your xp and restart your pc and your problem will be solved
if still having problem then you must reinstall windows xp
Mar 07, 2008 | KDS Valiant 671DP Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
181 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
