Just started resetting itself after every picture. Sometimes it does it several times in a row or when I am about to take the picture it shuts down and restarts itself. Just started doing this, but uses by battery up fast because of this.
Your P712 has the P-series power switch problem. Look here:
http://www.dpreview.com/forums/post/54537282
Can be solved by using WD40 or Dioxid.
SOURCE: Kodak p712 shuts of and lens retracts
try resetting the timer to shut off the camera after a period of inactivity to a longer time. It seemed to work for me
SOURCE: My wife`s Kodak Easyshare V1253 has to be reset
Regarding the date and time, Actually its normal everytime you removed the battery you need to reset the date its is because the camera doesnt have a internal or built-in battery that can run the internal clock or maintain the date settings.,
Regarding the taking picture that will take time, it is because your using a too high mega pixel of the camera, Higher mega pixel will have a bigger file size and it will take to process the picture. the best thing you can do is to lower the Mega pixel or the picture size make it atleast 5MP or 6MP., I can guarantee to you you will have a great picture outcome and lessen the time of processing picture.
By the way you can lower the mega pixel (picture size)by pressing the menu button of your camera
SOURCE: My Kodak easyshare P712 keeps shutting off when we
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: batteries in my kodak easyshare camera don't last
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Turn on your camera without the memory card.
SOURCE: kodak easyshare Z740 battery problem
I may be able to help with your Kodak EasyShare Z740 that turns itself
off.
Try these steps to fix your camera.
I
hope that helps.
_____________________________________________
Turns Off Fix
Manual Download
