Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Need to format
I need to format my Maxtor III to FAT32 not NTFS dont know how or if I can
  • ibanez1973 Oct 04, 2007
    My computer does not give me the option to format in FAT32 only NTFS is there any way to input the format FAt32
    Brigadier General:
  • 6,966 Answers
Hi, You can try: 1. Open your "My Computer" and determine which of your HDs is the Maxtor III, say "E" or "F"; 2. Right click on the Maxtor III; 3. Click on "Format"; 4. On the File System, select FAT 32; 5. Click on "Start" Of course formatting your HD will delete its content. Alternately, you can: a. Open a command prompt window (type "cmd" in "Run"; b. type "format E: /fs:FAT32" assuming your PC assigned the drive letter "E" to the Maxtor III; c. hit "Enter" If for some reason this will not work, you may have to likewise delete the partition first. A handy 3rd party utility for the partition/format of a hard disk is Partition Magic. Hope this be of some help/idea. Post back how things turns out or should you need further information. Good luck and kind regards.
Posted on Oct 04, 2007
  • Louie  Role
    Louie Role Oct 04, 2007
    Hi again,
    As initially posted......
    c. hit "Enter"
  • Louie  Role
    Louie Role Oct 05, 2007
    Have you tried the partition Magic?
I am having a maxtor One touch 111 external drive which I need to connect to a fedora linux. Do we have a linux driver which can detect the USB drive
If you are just using it as an external drive, Fedora should see the drive automatically, no driver should be necessary. If it can not, there is probably a different issue.
You may need to format the drive if order to mount it.
If it is already formatted as NTFS, it will be read-only to Linux. If formatted at FAT32, Linux should be able to read-write it as well as Windows.
fdisk -l: to get info on all disks (formatted or not) connected to the box. You should be able to figure out which disk is which.
If you will be using this disk exclusively with Linux, you will probably want to consider formatting it with a native Linux file-system.
Nov 30, 2010 | Maxtor OneTouch III 300 GB Hard Drive
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
I have a Maxtor 3100 100gb external HD and tried to backup my computer and it would only backup 4gb. I got a message that if the HD is formatted in FAT32 it would only backup 4gb. I need to backup about...
1. Please connect you external HD to your computer
2. Fat32 can only handle a limited amount of data
3.Go to the Control Panel
4. Open up Administrative Management
5. Open Computer Management
6. Open Disk Management
7. In the denter panel you will see your Maxtor expressed
8. Right click on the drive
9. Click format
10. Choose NTFS
if not given the coice, it will usually format to NTFS anyway, but get smart, explore Disk Management and make sure
11. I'm giving a general scenario across 3 different Windows OS Sytems
12. When you tell us your exact Operating System, we can be more helpful
TheSelkie
Oct 04, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I have been using Maxtor basics desktop 500mb with my desktop PC (XP) for a year. Now I have an Apple Mac Mini and so I want to use the Maxtor with the Mac and access the files on it from the Mac (OX Snow...
Looks like you may not be in luck.
I found this on a forum.....
When you have the hard drive connect to the Mac, right click on it's icon and select Get Info. Look in the window that pops up and see what is listed next to Formatting. It it says NTFS, then the Mac can't write to it. Being it is a large drive, that you have been using on a Windows PC, I'm 99% sure it is NTFS. In order for the Mac to write to it, you will have to erase and reformat the drive. If you will only now be using it on the Mac, then you can format it Mac OS Extended (Journaled). Just remember, that by doing so Windows now will not be able to read or write to the disk. If you do need it to work with both platforms, you will need to see if Maxtor has a utility to do the formatting. Because of it's size, I know that Windows will not format it FAT32 (which is the format you need it to be in for both OSes to read and write to it) in one drive as Microsoft has limited FAT32 formatting to only 32Gb, but can read FAT32 drives of almost any size. The Mac can format MS-DOS (FAT), but I have not had the greatest luck in formatting large drives with it. The Mac will see and read/write just fine, but many times, Windows will not see the drive. I know that most drive makers do have a utility that runs under Windows (some even have Mac ones) and will format it for you in FAT32. There is one downside though, you will not be able to have a file greater then 4Gb in size due to a limitation is the structure of the FAT32 data table
Aug 05, 2010 | Computers & Internet
How to unlock my hard drive?
throw it away and buy a new one....that the best solution i have
Feb 18, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
External hard drive not recognised on my ps3??
Ok. Well this is easy! your hard drive is formatted in NTFS, ps3 wont recognize that. it needs to be fat32 find an XP machine not a vista machine.
download Swiss Army Knife and format the drive in fat32. you will loose ALL information in your external. you will need to back up anything you want to save and put it back after the format.
good luck!
Feb 09, 2009 | Maxtor Hard Drive
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
I am unable to format my Maxtor One Touch III 500gig External Hard Drive. Once i get to 100% using ms disk manager, a message box pops up saying that it was unable to format the hard drive. In linux when i...
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Mar 22, 2008 | Computers & Internet
Re-partition external HD for windows and mac
Back up all the data on the disk to your Mac. Plug the disk into your Windows computer and format it with a FAT32 filesystem. Both Mac and Windows can use FAT32. Do not format as NTFS.
Jan 18, 2008 | Computers & Internet
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
233 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
