Question about Panasonic PT-53WX54 53" Rear Projection HDTV
TV wouldn't stay converged them went black
My TV just started to lose its convergence so I converged it. I had to do this twice in about a 10 min timeframe. It then went completely black. I decided to change the convergence amplifiers, but the TV is still black. Any help on this is greatly appreciated.
  • 3 more comments
  • bama24mp Oct 06, 2007
    I really can't check the resistors now. My ohmsmeter is not working. Any other ideas?
    If you would recomend changing resistors, are those the only two?
  • bama24mp Oct 07, 2007
    I just bought one online and will have it in a few days. I will be able to test then. Maybe we can get this fixed. Thanks again.
  • bama24mp Oct 10, 2007
    What about R846?  No resistance is showing through it.  R847 is ok and I can't find R841.  I checked the continuity of the fuses and all seemed ok.
    I checked almost every resistor and fuse i could find and all are good.  Even R846 (bad battery in DMM gave me a false reading).. Any other ideas?
How do i find the different converg on my tv
Posted on Dec 17, 2008
  • deadsoulblad Dec 17, 2008
    how do i find the other converg on my tv
  • 1,153 Answers
There are also fuses that goes with amps and return resistors to that need replacing. To be precise you need live chat!
Posted on Oct 04, 2007
  • 1 more comment
  • Lashawn Robinson Oct 05, 2007
    Sorry didn't get back just want to check in with you. Found also R847, R841 may need changing.
  • Lashawn Robinson Oct 07, 2007
    You really need that meter to check these resistors. They maybe acting as fuses, which is your problem. There are fuses that blows that cause problems when replacing converg. amps, if you have no solder bridges.
  • Lashawn Robinson Oct 08, 2007
    Yes, just let me know of any changes!
I have a completely black screen on my tv, but i am hearing sound
Ur tv have convergence problems,it dead.U must know how to solders,have soldering tools,and solders to fix convergence problems.U must replaced 2 STK Convergence ICS,and some or all it resistors.Tries wesites like Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 08, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Tv turns on but the screen is black. Before it went black we were haveing bands of color on the top and bottom and everthing was kind of like in three D they were all three colors and like 3 of them there.
Ur tv have convergence problems,now the 2 STK convergence ICS are completely dead,U lucky u tell it was 3D screen,before it go completely dead,went black screen.Or ur problems it will very hard to diagnose.U now how to do soldering?Must replaced 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 03, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
My color convergence is messing up on my rca p56924 when I turn it on its normal after 10-20 mins all of the colors split
Resolders the 2 convergence ICS and all it resitsors.Well get convergence back to normal.Not than the 2 convergence ICS must replaced.Try Website Tv Repair for a convergence kit to repair it ur self,if u Know how to solders?
Feb 15, 2010 | Televison & Video
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
52' take about 15 min. to come then only stay on for about 1hr
The convergence ICs overheat , you get bad picture and then the TV detects the fault and go in protection mode, that is the standby state.
That means that the convergence ICs are bad and must be replaced, the job is about $200/$300.
Here there is an example of the repair needed: Fixing Convergence problems in RPTV's
Mar 09, 2009 | RCA HD52W59 HDTV Projection Television
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
Mar 24, 2008 | Televison & Video
Mitsubishi ws 46807 convergence
convergence fail. try resoldering the 2 convergence ICs in the middle baord located on the large heatsink. this might fix unless the problem has gone it course
Mar 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Tv went black and no sound standby light falsh twice and paused and flashed twice again
This indicates a short happened somewhere in the set, causing the set to go into "safe mode" where it won't let itself turn on. Oftentimes it's the convergence board. Depending on what that will cost you, you may want to just replace the set.
Mar 01, 2008 | Sony KP-61HS10 61" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
