Led screen wont light up.
Hi, my led screen wont light. Do I need to replace the 14v lamp? How much to repair do you think? Cheers.
    Genius:
  • 1,153 Answers
Does it works besides the lamp? If so then this can be cheaply ordered from bluestar-online, Mcmelectronics, tritronics
Posted on Oct 04, 2007
SOURCE:
How do I connect a warning/ignition light to my alternator?
Hi Glen
All depends what you mean by warning lamp.
Early Alternators used to have a terminal connected to the "Star" winding inside. A 12v lamp connected between here and ground will light up when a charge is available.
But.... the simplest method is to buy LED charge lamp which checked for voltages above 12v (12.5 to 14v} and lights up showing a charge. I can buy a simple device like this from my local Jaycar Electronics store. You should be able to get a similar device depending on where you are
Good Luck
You searched for alternator test
Oct 07, 2015 | 2004 Ford Focus
I think that the led light burned out
You do know the lamp won't light unless the projector has an input source connected?
It's not designed to be repaired because there are safety issues in case you put too bright a lamp in, after all it is a children's toy. That said you have 2 options, take out the old lamp, and identify it, that should be fairly easy, or contact the distributors.
Contact JAKKS
Jun 16, 2014 | JAKKS Pacific EyeClops® Mini Projector
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Hi, We have a Toshiba rear projection tv model 46WH08G which wont turn on. by this we mean that the red power led light is on and weve noticed that the green led light alongside is flashing, which has a...
It sounds you need a new Projection Lamp; they usually last for 2000 hours or more. The led blinking is the lamp warm-up period and it fails now, if you replace the lamp be careful very static sensitive and blow the dust out with air while the TV is open. Hope this Helps.
Apr 08, 2010 | Televison & Video
Tuning lamp on Proton 320 clock radio
The bulb is a small electronics bulb on the left side of the lexan display cover and it is covered with an insulated foil tape. Measure the voltage on the bulb with a voltmeter and go buy a replacement from any electronics supply place or radio shack.
Mar 22, 2010 | Audio Players & Recorders
Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
Dec 24, 2008 | Office Equipment & Supplies
Energy S 8.3 Woofer; blue led doesen't light up
Bought a S10.3 in jan/2010, LED died a month later. I've repaired it by myself. After inspecting circuit, I've found that their design puts almost 14V of reverse bias upon that poor blue LED. These components are not usually expected to sustain more than 5V of reverse polarization. So, in my opinion, there is a design flaw. To make a long lasting repair, you just need to insert a general purpose diode in series with the LED, such as an inexpensive 1N4148 ($0.05). And, of course, any readily available 3V, 5mm, through-hole round blue LED (I think crystal clear should be better).
Sep 09, 2008 | Energry Speakers Energy Speakers S8.3...
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
Wd52725 problem
code 12 means no error detected. However when your lamp wont light and you have replaced the lamp it is usually traced to the cpacitors on the PWB PCB that need replacement. You can get a repair kit for that model at the following link. Its called the V26 PWB PCB repair kit. which contains all the capacitors and a CD with the capacitor board locations and disassembly instructions and board Identification and full Service manual for that model DLP. Heres the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Nokia 6233 water damaged...
Unfortunately, probaby both, plus the keypad, other selector buttons, camera and speaker.
Most likely would cost more to repair than to replace.
Mar 26, 2008 | Nokia 6233 Cellular Phone
273 people viewed this question
Ekse
 Grubhead
Grubhead
