Question about JVC KD-G200 CD Player
Sound not good
I have a JVC KD AR200 which was working fine until Sunday, I turned it on there was a whooom sound, now the music sounds very faint like in the back ground out of both speakers, I have to turn it up really high to be able to hear it. Have you any idea what might of caused it? Thanks David
    Problem Solver:
  • 14 Answers
Could have blown the speakers or if there sub woofers ran off an amp that might be your problem as far as the cause it could be something as simple as a loose ground or some wire that is getting power grounding out on a piece of metal somewhere i would double check all of your connections
Posted on Nov 18, 2008
SOURCE:
My jvc kd-g430 is working but no sound is coming out
If it was installed in a vehicle with a separate power amplifier, the fuse for the power amplifier may have blown
Nov 28, 2012 | JVC KD-G430 CD Player
What are good settings to have to make the music sound clear for a jvc KD-R310 deck?
you will need to access the bass and treble setting on the unit.
If you have stnadard speaker then dont put the bass to high as you can not turn the volume up high.
The same for the treble.
Set them at about the same and turn the volume up until it sounds good.
If it is to quiet then turn the treble and bass down and then the volume up more
Mar 02, 2011 | JVC AM FM CD DET FACE CAR STEREO
Wiring problem with jvc radio and Pontiac Montana, looks like everything is wired correctly. Connected yellow wire to dimmer and illumination wires in metra connector for Montana. Unit will eject a cd but...
YELLOW WIRE IS CONSTANT, SO YOU NEED TO FIND A CONSTANT POWER SOURCE. GET A TEST LIGHT, GROUND IT, AND TEST THE WIRES WITH YOUR CAR OFF AND KEYS OUT OF THE IGNITION. MAKE SURE IT HAS A GOOD GROUND. LET ME KNOW HOW THAT WORKS OUT.
Dec 02, 2010 | JVC Arsenal KD-AR200 CD Player
How do I get this unit out if I dont have the
take the faceplate off the dashboard, then you will see the mounting screws
Jan 02, 2010 | JVC Arsenal KD-AR200 CD Player
How to set the displayed time in JVC KD-G110 car music system?
Turn your JVC source ON. Then press SEL -button continuously, until you see the function change mode. Then select desired function with rew/fwd -buttons, and change mode vith -/+ -buttons.
Apr 01, 2009 | JVC KD-G110 CD Player
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
Jvc sirus and ipod issues
I am having exactly the same problems. No sirius and ipod has to be turned up very loud to hear at all. The problem appeared suddenly friday night with no movement of accessories. It was working when I turned it off and wasn't when I turned it on a few hours later. I have checked connections and reset unit with no success.
Oct 02, 2007 | JVC KD-HDR1 CD Player
JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
JVC KD-G200 CD Player Logo
62 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
