Question about HP DeskJet 712c InkJet Printer
Only prints red
Does not print all colors just magenta
  • 4 Answers
It sounds as if the printhead needs cleaning. There should be an option on your printer for doing this. You may need to run this a number of times. If that fails to work, then its possible that ink has clogged the jets. Time to replace it.
Posted on Nov 23, 2007
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 28, 2015 | Konica Minolta BizHub C252
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
We print color labels for dental folders. The Magenta is running out much faster that any other color by three to one.
If you are printing red or magenta tone colors more than any other the printer will use magenta much faster than the other toners.
Jun 09, 2010 | HP LaserJet 3600n Printer
Colour problem
If the printer gives magenta instead of red you have a problem with one of the other colors. Magenta needs other colors to print red. Print a cofiguration print and check witch color is bad or missing. Replace the cartrridge of the missing/bad color
Dec 24, 2009 | HP LaserJet 3000n Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
HP DeskJet 712c InkJet Printer Logo
62 people viewed this question
Clive
Clive
