I think my battery might be bruised or my computer itself might just need to be fixed all together.
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
SOURCE: Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
SOURCE: open the computer
The Hardware Maintenance Manual for the - ThinkPad T40, T40p, T41, T41p, T42, T42p can be found on the lenovo web site at
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46464
or
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/39t6192_01.pdf
The document requires adobe reader thats available for free at www.adobe.com
SOURCE: I have a flashing/blinking orange battery light.
Most likely you have a problem with the battery or electric circut in your laptop. Unfortunatly there is not much you can do, except taking it professional repair service.
SOURCE: Dell Mini Inspiron 910 battery
Please refer to the following 2 articles to diagnose & fix your problem:
http://www.fixya.com/support/r6416355-troubleshooting_laptop_battery_problems
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
