Question about SanDisk Sansa m230 MP3 Player
Mp3 sansa m230
My sansa mp3 only says initializing updates and my pc will not recognize the player when plugged in
  • Anonymous Nov 28, 2007
    i had 114 songs on my sansa m230. it worked for like 2 weeks. now it freezes on the sansa logo. my computer wont even recognize it. please help!!!!!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
Operating System does not recognize San 230
What is your operating system? You may need to update your usb drivers.
Aug 28, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230
Try updating Windows Media Player and seeing if that helps.
Dec 26, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Initializing
May 03, 2008 | SanDisk Sansa m230 MP3 Player
Pb for my sandisk m230 mp3 player
Same thing happened to me... try this...
1) disconnect all cables
2) turn power on (hold menu button until screen lights up)
3) Press "menu"
4) scroll down to "settings"
5) scroll down to "USB"
6) select "MSC" (default is probably auto detect - which I think there's a conflict with)
7) turn power off (holding the menu button down)
8) connect USB to computer and hopefully start loading files
I bought 2 of the 512 models, one didn't work... so I took it back and had to buy a 2gig model... got home and it didn't work! I tried the above for the new one and at least the computer recognizes it! Everything seems to work fine...for now...
Dec 03, 2007 | SanDisk Sansa m230 MP3 Player
Sansa m230 (512 MB) MP3 Player still not working after do what you told me
i download an update from the site that solve this to me. but in another time, mine only works when it's plugged to pc,then open the device and cut the tiny battery that have inside (CR621 or something like this) it was shorted.
Sep 07, 2007 | SanDisk Sansa m230 MP3 Player
MWP does not recognize my san disk m230
i suggest an update software ,this will solve the problem.
May 31, 2007 | SanDisk Sansa m230 MP3 Player
My mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Nov 27, 2006 | SanDisk Sansa m230 MP3 Player
San Disk Sansa m 230 512 MB
Your problem is probably beacause you accidently deleted "AudibleActivation.sys" from your "Audible"-folder. Format the sansa and then use "reset to factory settings" to make the file appear again. It might be a good idea to make a backup on your hard drive, just in case, and make the file hidden.
Oct 31, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
