Question about Nintendo DS Lite Console
Nintendo DS The Touch screen works sometimes usually not in the area you are touching it. Help!
  • mini man Nov 25, 2007
    my ds lite's touch screen is tempremental , it works sometimes and other times it doesnt want to know- Help !!
    Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • Nintendo Expert
  • 127 Answers
If the touch screen still works then you have the option to calibrate the touch pad via the NDS utility and the stylus.
If you cant recalibrate the touch pad then is very posible for it to be damaged and you shoud consider replacing the pad with a new one as you can find these replacements widely spreaded in the web not so expensive.
You can also find guides and videos on how to dissasemble the device and replace the touch pad by yourself taking care at all times to avoid causing a worst damage. You need a thomson screwdriver, usually sold in the same store where you find the pad and some small blade and philips screwdrivers. And a lot of patience...
Good Luck...
Posted on Oct 17, 2007
6ya staff
SOURCE:
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
My Nintendo touch screen does not work.
Well, does the screen turn on and function correctly? If so, then you simply have the touch screen ribbon that is disconnected and if you open the DS you can correctly place the ribbon so the touch screen functions.
If you don't want to take the chance of screwing it up more, then simply sell it on eBay. You will get a good price if you describe the problem. Others who are experienced in this area will buy it, and that money could help you get a new one.
Oct 07, 2008 | Nintendo DS Console
Touch screen doesn't light up
Your problem is with the LCD behind the touch screen. The bottom scren on your DS is actually two screens. An LCD and a touch screen on top of it. Either your cable has come loose inside the DS or the LCD is possibly bad. This can be fixed.
The other option is that the electronics feeding the LCD have gone bad in which case you might as well buy a new DS. But check the screen first.
If the DS is under a year old you can send it to Nintendo for free repair.
Mar 04, 2008 | Nintendo DS Console
Nintendo ds NEED HELP
My DS touch screen is very light. If you turn look at a particular angle you can still see what is shown on the screen, but other than that, the screen looks white. I have already changed the touch pad and that was not the problem. Any assistance would be appreciated.
Thanks
Feb 04, 2008 | Nintendo DS Console
Nintendo ds touch screen
i had the same problem and have now fixed it succesfully the touch screen works like a grid and is overlayed onto an lcd screen so that when you touch the screen it makes a conection within the grid so that the machine knows where you are touching .....if one of these grids are broken you will never calibrate your screen as the ds doesnt recognise what you are touching .....in short the answer is to replace your touch screen
Jan 06, 2008 | Nintendo DS Lite Console
TOUCH SREEN NINTENDO DS LITE
aparently fitting a new touchscreen works, i have just ordered one from ebay, cost me a tenner
Dec 31, 2007 | Nintendo DS Lite Console
Touch screen
Contact Nintendo. as you didnt say if it was a DS or a DS lite
go to http://www.nintendo.com/consumer/systems/selectds.jsp
its Nintendos DS Customer Support.
Dec 25, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Touch Screen Fades
You're going to have to send it in for repair. It sounds like it's out of warranty, which is unfortunate.
Dec 05, 2007 | Nintendo DS Console
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
