Transmission went into neutral while driving and it has stayed in neutral since then. Only functional shifts are parking, reverse and neutral. It does not engage any forward shifts, either in "D" or manual.
Check transmission fluid level if low on fluid it will suck air and transmission forward clutch can not apply. If fluid is full and clean looking RED in color shift control solenoids are the problem and internal. BROWN and BLACK fluid indicates the forward clutch was slipping and now has no holding power for movement. this case the transmission needs reconditioning.
SOURCE: 2002 hyundai santa fe transmission will not engage
You might have lost your lower gears, I would have someone look at it to see if your gears are gone or if its just a faulty sensor.
SOURCE: My Transmission will not shift into forward gears
Does the Check Engine light come ON when this happens? Whenever the "Check Engine" light comes on, there is always a DTC (Diagnostic Trouble Code) stored in the ECM (Engine Control Module). You'll need an OBDII (On-Board-Diagnostics) scanner to retrieve any codes recorded/set in ECM. Once you do this and let us know what, if any codes are set, then we can go from there.
Take/tow the vehicle into a Hyundai Service Center (dealership), pay the diagnostic fee. They will tell you EXACTLY what the problem is and what's needed to fix it (parts, labor, tax, time-frame, etc.).
Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
SOURCE: transmission will not shift
Check the Vehicle Velocity Sensor (V V S)-(Speed Sensor) or the wire harness to the VVS. IF the ECM is not getting a signal from the V V S, the PCM can not give the signal to switch gears. The V V S is on the drivers side of the end ot the transmission that is held on by one bolt. Best thing to do is to have the truck scanned at Auto Zone for a DTC code and to confirm that the V V S has gone bad and they can give you the step by step instruction to replacing the sensor and takes about 15 min to do. Good luck and keep me posted. Keep an eye on the transmission fluid, make sure you don't run the transmission to hard and burn it out over a $40.00 sensor which is better then $1,800 for a transmission replacement.
SOURCE: 2002 hyundai santa fe front transmission leak
swap w/rear radiator rear doesn't require fluid.
SOURCE: 2001 Hyundai Santa Fe - Engine Code P1602, stuck in gear
Im having the same problem with my 02 Santa Fe. How do i go about fixing this problem? And is it costly? Please help
