Question about VillaWare 5787 Double Smoothee Work Top Blender
5787 we need new pitcher and two blade units
I have the double machine and need two replacement pitchers. where can they be found?
Posted on Jul 31, 2008
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
I need the plastic pitcher model 5787 for the villaware double station smoothee bar.
i HAVE ON I BROKE MY GEAR INSIDE THE UNIT AND NOW AM STUCK WITH A NEW UNIT THAT DOES WORK   donald0936@live.com
Dec 23, 2010 | VillaWare 5787 Double Smoothee Work Top...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I need a replacement pitcher for my Bobby Flay blender but can't find one...
I actually have the pitcher, it comes w/the chigger and the blade that connects to the bottom of it.
this part is brand new, let me know if you still need one.
Jun 16, 2009 | Blenders
Need a new plastic pitcher for our villaware 5787 Smoothee
Got the number from your website and called direct to VillaWare...waiting to see if it arrives safe and sound, thanks so much!
PS...There are only a few left of this now discontinued model, so I'm glad I called (and I ordered 2 more instead)
Jun 01, 2009 | VillaWare 5787 Double Smoothee Work Top...
I have a dual 5787 blender that the jugs are leaking. Can I purchase new ones?
hello
can i buy just the blade kit?
please let me know
Oct 18, 2008 | VillaWare 5787 Double Smoothee Work Top...
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Dec 27, 2007 | VillaWare 5787 Double Smoothee Work Top...
Hello Guest - Would you have the number? I can't find it anywhere...thanks!
Oct 19, 2007 | VillaWare 5787 Double Smoothee Work Top...
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
VillaWare 5787 Double Smoothee Work Top Blender Logo
205 people viewed this question
Top VillaWare Blenders Experts
Steve Allison
Steve Allison
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
