Question about Mitsubishi CS-27205 TV
Connecting to a DVD/VCR player/recorder
I don't have an owner's manual for my TV. I bought it from my daughter-in-law's friend. Anyway, I'm trying to hook it up to a DVD/VCR player/recorder. I hooked it up to the TV as shown on the DVD/VCR player's manual. I can get into the setup menu to set the clock and then to the programming menu just fine, but I can't figure out how to get it to indicate which channel I want to record. The line that should say "channel" says "INPUT LINE 1" or INPUT LINE 2". I don't get it. I called Philips (manufacturer of DVD Player) and they said I was supposed to auto program the channels??? That's all they said - they weren't very helpful.
  • smuthlvr Dec 26, 2007
    hello i am trying to connect my phillips [dvp3340v/17] vcr & dvd player to my tv its a mitsubishi [19A25] i can't get my vcr & dvd player to work could it be that all that i now need is an s-video out cord that goes to the back of my cable box? if so please let me know my name is Andrew and my e-mail is quaknbush7455358@aol.com
    Genius:
  • 1,694 Answers
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Posted on Oct 04, 2007
Vcr won't record
first try a new set of connecting wires these are the usually cheap wires that will give out easily. if that don't work ,its most likly gonna be the tape recorder itself. how old is it.
Jan 21, 2012 | GoVideo DV1130 DVD Player/VCR
How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
Oct 20, 2011 | Toshiba DVR670 Player
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Need password
With no disc in the player
1) turn on.
2) press open key.
3) press 5168.
4) select rating.
5) select "adult" or whatever rating you would like.
6) select setup.
Aug 08, 2009 | Broksonic DRVCR900 DVD Recorder/VCR
Coaxial cord won't fit on VCR/DVD
Are you sure that the port that is unthreaded is actually coaxial. I've never seen an unthreaded coaxial port, just unthreaded push on connectors.
What color do you see on the center ring on the connection of the vcr?
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Converter box
The cable that goes into the TV sould come from the VCR output to TV plug.
The antenna input to the VCR should come from the antenna or DTV converter box.
The signal passes through or loops through the VCR.
If you hve a manual the connections are on pages 14 an 15.
Let me know if there are any problems and a time you might be hooking this up.
You can download a manual here:
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Oct 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Televison & Video Logo
210 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
