Question about Palm TX Handheld
Palm TX To Do List
When I check off an item on my to do list, directly on my palm, it wont synch with my desktop. And the checked off item will come back as "un checked". Also so of my programmed to do list items have begun to duplicate, what shoul I do?
    Problem Solver:
  • 14 Answers
Hi, if you are using palm desktop as your default sync program like i de, you may want to check your conduits and see if they are all on sync mode. try to sync after and tell me if that works.
good luck and enjoy
Posted on Nov 10, 2007
  • Mikell Jaas
    Mikell Jaas Nov 16, 2007
    to change the conduits try this. on palm desktop, go to hotsync-custom- scroll down the littlle window till you find tasks. double click on it and click on synchronize the files. this might help.
    As for the duplication. this happens when you make a change on the TX on a record and make a change on the desktop on your computer. instead of jumbling up your file the hotsync will just create another 2 files each reflecting the individual changes and leaves you to decide which copy you do not want.
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ... > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Need to move contacts in Palm Desktop to new user name
On your Palm Desktop, under username PalmUser40, select the category view of 'All'.  Then press Control + A to select all contacts. Then press Control + C to copy them all.
Then change the username on the upper right to 'misty'.  Then go to contacts, under category 'All', and then Control + P to paste all contacts.
This will most likely not keep all the category names, but all your contacts will be copied in.
Then hotsync to sync to your Palm TX.
May 19, 2009 | Palm TX Handheld
Palm TX won't synch with Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Apr 16, 2009 | Intel Palm Tx Handheld
Can not synch my palm tx to new computer with vista.....
Download the newest Palm Destop software from this link:,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
The new version works on Vista units.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 31, 2009 | Palm TX Handheld
Can Palm TX, E2 and z22 all use the same program
You might just have to upgrade the desktop software to work with the TX.  You can keep your names and addresses but you have to check with each program to see if there compatible or not since the TX uses Palm OS 5.  Most of the software available today is written for that operating system.
I don't believe Palm is even supporting the E2 anymore.
Oct 07, 2008 | Palm TX Handheld
Palm T/X synch problem
Make sure cable connected properly and Palm desktop software installed correctly. You may obtain latest palm desktop from link below
Jul 07, 2008 | Palm m515 Handheld
Palm Zire to itouch
Those two devices are not compatible to one another. You may get it to work by exporting the Palm desktop data into a CSV file and importing it into the program you use to sync the Itouch with.
May 22, 2008 | Palm TX Handheld
Half of my Palm Desktop Contacts disappeared
I've had the same problem a few times.  In my case from middle of P's to Z.  I am able to salvage most of the list doing a hot synch with the "handheld overwrites desktop."  I'm afraid to do a normal hotsynch b/c the desktop may overwrite the handheld.  PALM SHOULD FIX THIS !!
Jan 26, 2008 | Palm LifeDrive Handheld
Hotsynch manager does not list mail as a synch task
When you first install Palm Desktop, you have a choice of synchronizing with Palm Desktop or with Outlook.
It sounds like you chose Palm Desktop.
You have to uninstall Palm Desktop and Reinstall it.
There will be an option to synchronize with Outlook/Versamail so make sure to choose that.
Sep 11, 2005 | Palm Zire 71 Handheld
Synch question
If you have PocketMirror from Chapura (included with certain Palm handhelds), you can choose to install conduits that synchronize MS Outlook with the handheld applications Date Book, Address Book, To Do List, and Memo Pad. You can choose to synchronize these applications with either Palm Desktop or Microsoft Outlook, but not both. If you want to synchronize with Microsoft Outlook, DO NOT install Palm Desktop from the Web. Instead, run the Palm Desktop installer from the CD that came with your handheld and select the option "Synchronize with Microsoft Outlook" when the choice appears. Visit for more information about Chapura(R) PocketMirror.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Palm TX Handheld Logo
50 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
