Question about Garmin StreetPilot c340 GPS Receiver
Internal battery The battery on my Garmin C340 never had any problem keeping a charge before, then one day it completely failed and will not accept a charge from the car, even though the screen on the GPS is telling me the battery is charging. The unit does work fine as long as it is in the cradle. I did notice the day before, the suction cup had failed and fell off the window with the unit attached. It happened over night and was hanging by the cord for what could have been hours. I've opened the unit up, and looked for loose wires, but found none. The plate at the top of the unit (which I believe is the antennae) did slide out very, very easily.... it had two black wires attached to it, but I would have thought it would have been anchored in place. I put the unit back together again, and it works just fine as long as it is in the cradle, but as soon as the car is turned off, the unit goes dead. I did hit the reset button to no avail. I've also hooked it up with the USB cable to the computer, the unit turns on, but again, the battery doesn't accept a charge. Any thoughts?
  • 5 more comments
  • SJGWeb Nov 10, 2007
    My battery is dead too, won'y hold a charge at all! Is it really the battery, or something else? Unit is less than two years old... seems the battery should last longer than that.
  • seadoo969 Nov 26, 2007
    battery wont hold a charge anymore? and it takes sometimes mins to locate satellites which it never took so long?
  • edd1216 Dec 08, 2007
    I guess my battry is dead too, would not hold charge even though ther's a message on the screen that the battery is charging. It would only work once you plug it in, but it will take a long time to locate satellites. It's only 14 months old.
  • wworks Dec 26, 2007
    My battery barely holds a charge, when it goes into lost power do you want to continue it does not get to the 30 seconds to shut down.
    Sometimes if I start te car up and it comes on and then shut it down for a second or so it won't start. I found the reset button and now that seems to start itback up again. No loss of even destination.
    Wish the battery was replaceable.. Just got the map upgrade for a gift and wondering if it is worth downloading it if it is going just die soon.
  • Anonymous May 15, 2008
    Shame, I've used several GPS units and I really like the UI in the Garmin. But since the battery has died and I assume that has something to do with why it now takes 15 minutes to find satellites, I'll probably not get another Garmin. I want to throw it away now.
  • dcd9086 Jun 18, 2008
    Battery will not take a charge. I've hit the reset with no results. Can the battery be replaced
  • jazzy-judy Jul 17, 2008
    My Garmin c340 turns on and after a minute turns off or says battery low. While plugged into the car. The car receiver is working..
Can you explain to me please how to take apart my garmin i have the same model and i need to know how to take it apart...to disconnect my internal battery long enough to reset the system...please contact me ova email at toy9cito@yahoo.com or thru aim:toy9cito thanks...
Posted on Dec 16, 2007
My Garmin has the same problem. I contact the Garmin technical support service and describe this problem, and I were told that my unit may not operating correctly from what I described, and should be returned to the factory for service.
The flat rate of repair for this unit is $150.00, however this would be covered under warranty if it is less than one year from the date of purchase. I don't recommend to repair your unit if it was out of warranty. You can buy a brand new one at this repair cost. You might know that Walmart is now selling this unit at about $180.00.
Posted on Nov 30, 2007
My garmin in nuvi 1350 will not charge it keeps saying the battery is low
Nuvi 1350 charges in 4 to 8 hours. If your Nuvi is not accepting a charge, you may have a loose or bad USB cable. Note that the Nuvi can be charged with a phone charger. Charging it with a connection to a computer moves charging time toward 8 hours and more towards infinity if you don't have the driver installed on the computer. Turn the Garmin off. If the driver ins installed in the coputer, plug the Garmin into the computer and then hold down the power button on the Garmin for 30 seconds.
Sep 10, 2017 | Garmin GPS
Can not get StreetPilot C340 to turn on
Yes its most likely the battery, if you plug it into the charger, I assume it powers up normally? Il see if I can get you instructions on battery replacement. I remember there was one for your model or a similiar one. Hold on.
Oct 03, 2008 | Garmin StreetPilot c340 GPS Receiver
C340 is showing low battery. how do i change the battery?
It has a 12 volt power cable for the internal battery. Do you have the cable - refer to the owners manual (free download via the Garmin site) for more info. The internal battery is not normally replaced.
Nov 03, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 has won't turn on, screen is completly dark unit is charged
I has the same problem with a streetpilot 540.. It wouldn't turn on, even once charged. There was no reset button under the serial number. However, prise off the grey plastic square plate on the front panel which goes around the screen. ( there's even a little space for your fingernail under the Garmin logo). The reset button is under that plate. Press that with a screwdriver then turn on. My unit turned on once reset.
Aug 10, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging
From a complete drained battery it took me about 2 hours of charging via the USB cable hooked up to my computer to fully charge it.
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
335 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
