Question about HP LaserJet 2550n Printer
HP2550N PRINT QUEUE WON'T PRINT UNLESS TURNED OFF THEN ON
My HP 2550N has been installed for about 8 months working fine and I have it installed as a networkable printer along with other printers in my office. It is not attached to any computer only the network . In the last week, Whenever I print something, that print job stays in the print queue and shows as an error however if I turn the printer off then on, everything prints fine. I have loaded new print driver but same problem exhists. Also it does not matter who prints (I have multiple users) same problem. Any help would be much appreciated! Thanks, Majickstar (Rich)
    President:
  • 1,653 Answers
This definitely sounds like a driver problem so you will need to delete the old driver and then install the most current driver and patches from HP Support.
Also Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Posted on Sep 24, 2009
SOURCE:
Ip setup
Check the following link,
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c00262557&lc=en
Search for the TCP/IP settings from the Menu button in the settings and then you can manually change it.
Hope it helps.
Jun 12, 2013 | HP LaserJet 2550n Printer
How do I manually setup the ip address on the hp2550n
go to printer settings & set printer IP address.
Hp laserjet 2550n stopped prining in color, why?
Check your print driver settings. And if you are printing from any of the microsoft office applications look at the page setup to see if something was changed. Click file, then right near print is the page setup.
Nov 21, 2011 | HP LaserJet 2550n Printer
Document not printing! The document seem as though it goes to the printer and get lost in neverland. It clears the print queue.
I would update the drivers. Full instructions are on the HP website..Just list you model and search for Drivers.
The latest drivers sometimes help these problems.
Dec 17, 2009 | HP LaserJet 2550n Printer
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
HP 2550n will not print
From the HP User's Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
Here is a link to download the user guide:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00189910/c00189910.pdf
Oct 14, 2008 | HP LaserJet 2550n Printer
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Printer won't print
hmmm...that's a bit odd...you can disconnect from computer, and do a test page, to see if it's a core printer function, or something else(like blown drivers)
May 10, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 2550n Printer Logo
167 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
