Question about Intel Motherboard
Boot/wake-up HP Pavilion a230n will not power up unless I unplug the power cable from the motherboard, hold in the power button and replug in the power cable to the motherboard. Also PC will go into standby (sleep) but will not come out of standby (wake). Windows XP updates are current and BIOS has been updated. Tried all fixes on HP Cust. Service site and PC Doctor indicates that everything is OK...everything passes.
  • didim May 11, 2010
    Have you tried replacing your power supply if your have a spare one?
    have your tried replacing your power supply if you have a spare?
Dear Nikodi
The power supply may be paying tricks on you. Consider changing it. You can also test with another one before you switch them. It's usually the culprit in this scenario; getting ready to die..
For the standby problem, set everything in BIOS to default. If you don't know how, get someone to reset BIOS for you to DEFAULT. This runs without hibernating and restarts at the touch of a key or mouse.
Good luck
Posted on Feb 18, 2008
SOURCE:
After pressing the power button, my HP dv7-1129 laptop only stays on for about 2 seconds and then shuts off. I completely replaced the DC cable and now it receives power, but it does not boot up. What is...
try taking the battery out, unplug the DC cable and hold down the power button for 30 seconds this will get rid of the static on the motherboard which could cause the problem.
After you have done this put the battery back in, then the DC cable then try to turn it on.
If not it could be your battery because you are getting an indication that you are receiving power, try taking the battery out and just plugging in the power cable.
Hope this solves the problem.
Jul 13, 2011 | HP Pavilion dv7-1129wm Notebook
When i boot my computer the screen stays blank and two lights flash on the under side of the keyboard what does this mean
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion dv7-1129wm Notebook
Dear sir. my laptop hp pavilion dv5, its comming
Aug 27, 2010 | HP Pavilion dv5000z Notebook
Computer turns on but won't boot doesn't wake up monitor and it is beeping.
try resetting your bios (i.e. hold power button until it comes on, then goes back off, or taking out your cmos battery on the motherboard and hold a paperclip across the metal prongs for 15 seconds then replace battery) If that doesn't help, then I'd look at possibly a powersupply, ram, or motherboard failure
Jul 16, 2010 | HP Hewlett Packard Pavilion Slimline...
My hp pavilion slimline s3407c locked up and I
► do a power drain i.e unplug the power cable and press the power button and hold it down for 10 secs.
► reseat the hard drive by unplugging the cable connecting the hard drive and motherboard and also the power cable
Feb 08, 2010 | HP Pavilion Slimline s3407c Desktop,...
Hp tx 1000 black screen please hel
Nov 28, 2009 | HP Pavilion Tablet Notebook
The lights above the end button and the beside the caps lock are flashing and the system refuses to boot (hp pavillion 1x 2000)
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 28, 2009 | HP Pavilion dv8000z Notebook
Hp pavilion dv4000 will not wake up from hibernation
You have major problems. You should take it to a repair shop as it sounds like your motherboard is fried.
Oct 22, 2009 | HP Pavilion dv4000 Notebook
How do i reset my hp jetdirect 170x
Unplug the power to the HP Jetdirect 170x, press and hold the test button. while pressing the test button, plug the power cord back into the device and continue holding the test button for another 5 seconds.
This will reset the device.
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf
page 5-64
Aug 11, 2009 | HP Jetdirect 170x Print Server
Ink carts are full. cannot get to reset w/o the ! pt flashing. HP J3680
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Partial Reset
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the # and the number 3 button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the buttons..
Aug 11, 2009 | HP J3680 Officejet All In One Printer
Intel Motherboard Logo
117 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
