Samsung Digimax 4010 Digital Camera Logo
Zuleikha Makame Posted on Nov 07, 2013
Samsung ES99 i cant view my pictures from memory card
sean willam barrett
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 37 Answers
  • Posted on Nov 07, 2013
sean willam barrett
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
37
Questions
0
Helped
2056
Points
48
3 Related Answers
shaggyrat
Christophe Thompson
  • 1224 Answers
  • Posted on May 13, 2008
SOURCE: camera will not take a picture
an idea passed over my head just now
several ideas
was the camera droped
was the camera exposed to heat
was the camera exposed to static electricity
was the camera exposed to water or liquids
ect.
if these or other things happened to camera
the shutter inside camera has malfunctioned due to the reasons
tbreeze47
Tom Carson
  • 3083 Answers
  • Posted on Mar 30, 2010
SOURCE: I have a samsung S730 camera and when I turn it on
Sounds like one of two problems: the lcd could be bad, or the circuit that processes the pictures could be faulty. There are some ribbon cables inside the camera that can also get "knocked" out of their settings with the camera being dropped, etc. Service will be required to fix it, but you might just opt for getting a newer camera on sale, since the price of repair is often more than the old camera's worth. I've seen 10.2 mp name brand cameras on sale for $69...probably half the cost of repair. Sorry, wish I had better news.
Testimonial: "Thank you"
Anonymous
  • 3006 Answers
  • Posted on Oct 06, 2010
SOURCE: memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
How do i use the samsung wb35f camera
If you did put in a memory card, like it says on page 18 of the manual, the picture should be stored there. You should be able to view the pictures on the card, or you could put the memory card in an external card reader connected to your computer. Before you connect a card reader or connect the camera to any computer, install the software belonging to the device, or you won't see a thing.
I have Samsung ES99 camera but cant view my pictures to my camera its say file error even when i take out memory form camera to my phone its cant show any, what can i do????
If you have lost photo from camera then you may use photo recovery software to recover photo from camera. The software can easily recover photo. you may try this tool http://www.camerarecovery.org/
I cant format the pictures from camera
Try using a different memory card. Or use a memory card reader and format it using your computer.
I use pl70. i am having problem downloading my pictures. when i connect my camera to my computer i do not see my pictures, i have even tried inserting the memory card directly to my computer and i still...
1) Using new memory card. first connecting memory card to computer and format. and insert memory card to camera. making single shot. then connecting computer you see picture.
Memory card formating in camera may be not working computer or other device.
How do i view photos on computer
All you need to have is card reader for your camera memory card.
you can upload your photos by inserting your camera memory card to a card reader (should be compatible with your memory card) connected to the computer. your pictures will be downloaded immediately, and that's it. you can now view your pictures.
1helpful
I cannot access memory card to view pictures,
try your memory card in a computer to see if it`s still working, and if it is, reset your phone to factory settings (with the card removed) and try again.
3helpful
3answers
'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
2helpful
2answers
Samsung s850 cant copy from camera to sd card?
The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
Cant view pictures on the memory card
It could be that the resolution of your pictures are to high .
2answers
Lost pictures
As you lost your pictures from memory card, you need for a data recovery software to recover them. There are a lot of recovery software's at the market and some of them are even for free. Look for it in the internet, under "memory card recovering pictures" Good luck
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
