Aiwa HV-MX100 VHS VCR
Problem for Aiwa HV-MX100 VHS VCR
I am having trouble channel setting and recording.
By Natha on Oct 03, 2007
I went in to menu then channel set and tried to set channels. When i set the channels, and tried to record i still got a blank screen. The tv i have does not have a tv/vcr button, it has a aux channel. When i turn the vcr on, it displays in the aux channel. The vcr is plugged directly into the tv not the cable.
Same Problem
Nov 10, 2008
-   I havehad this VCR for 9 years, and have never been able to get this VCR to recognize the channels on my cable provider. I have carefully read and reread the installation instructions, double, triple, and quadruple checked my setup, and the machine steadfastly refuses to acknowledge the existence of any incoming signal from the cable. I can feed the same 75ohm coax into my Sanyo VCR, and have no problems. I can also feed the same signal to every TV I own, and have no problems. Only the Aiwa fails to detect the signal. This is not a huge problem, since I mainly use this VCR for playing European VHS tapes, but every time I've wanted to use it to record from the TV I have always encountered this failure.
Rgds
+-   PlusChap
Solution #1
posted on Jun 07, 2008
Not Rated)
Hijackthis1
Rank: Wiz
Rating: 79%, 159 votes
If you have a bad or fuzzy picture when viewing tapes on VCR then you need a new video drum. I think you can buy another that is for your brand on the internet. More VCR Repair -
http://www.videouniversity.com/vcrfirst.htm
Was this helpful?
Yes
No
Popular Solutions for Aiwa HV-MX100 VHS VCR
Questions and Unsolved Problems for Aiwa HV-MX100 VHS VCR
Do you recommend Aiwa HV-MX100 VHS VCR?
Answer
Answer
Hello . My problem is I put in a tape and the machine lights up only for two seconds and then turns... (More)
Answer
hi i have aiwa tv me pin code is blocked model no is vxt147k can you help
Answer
disc player will not spin on installation
Answer
Hi and thanks for your help. Didn't use it for 4 months, it worked fine before. Now I have a green... (More)
Describe your VCRs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top VCR Experts
Top Audio & Video Equipment Repairmen
in Newport, KY
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
