Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Thermador UCV36 - motor won't raise fan
My down draft fan broke last night. My wife pushed the button to stop the fan, upon which it started to retract itself without stopping the fan (correct operation would have been to stop the fan and stay put). I had to switch off the circuit breaker to stop it. After turning the power back on and pushing the button to raise the panel, the motor used to raise it started, but the panel stayed put. After a few tries, I grabbed the panel and managed to simply pull it up (I've never tried that before so I don't know if that is normal) all while the motor (but not the fan) was running. I think the mecanism to raise the panel is two jack screws, but I don't know for sure. Could anyone give me a few trouble shoot hints. Could something in the rasing mecanism have been dislocated, disconnected or similar?
  • Anonymous Nov 07, 2007
    I have the same problem - the vent is almost fully raised, and the motor turns on, stalled, when the button is pushed, and the fan is not on. It will not go down. Or up.
  • TK05 Nov 12, 2007
    My problem is with the 30" Cook 'n' Vent. The unit will raise and operate in all speeds, but when I push the button to retract the unit, it will not retract all the way. It acts like it is stuck about half way down. I am able to push the unit down, but it is very tight, like it is off the track or something.
Mrvica
  • 167 Answers
SOURCE: Downdraft up and down
this is ID 25898888.
Posted on Feb 22, 2008
  • 13433 Answers
SOURCE: thermador cooknvent downdraft CVS36R
My quess is you would have to replace the switch / button if its not working properly.
Posted on Oct 24, 2008
  • 112 Answers
SOURCE: 2002 Thermador Gas Oven door - can't get back on after removal!
You have to get the tension off of the hinge and it will drop right in. The spring loaded arm on the door needs to be drawn back until you can (depending on the style) either lock the u-arm into the notch on the other side of the hinge, or put a small bolt through the aligning holes in the side of the hinge. Once you get the arm straightened out a bit and relieve the spring pressure, you should be able to sit it right in there. Be careful though, that spring is strong.
Posted on Oct 25, 2008
  • 5 Answers
SOURCE: Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
How to change the switch on a thermador UCV36
Thermador Appliances ' Customer Support, Service, Repair ...
www.thermador.com/support
ThermadorThermador customer support is your appliance resource for FAQs, use & care videos, product registration, warranty information, service, repair and more.
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=63
ThermadorWe recommend that a Thermador authorized servicer change the seal ... refrigeration appliances, especially when the cooling function is switching on or off.
How do you install the up/down switch in a Thermador ...
www.shopyourway.com > Manage My Life > Questions
Get shopping advice from experts, friends and the community! I have a Thermadordowndraft vent model number RDDS30VRS that I need to replace switch part ...
Vent snorkel stuck in up position, fan works fine - Applian
Dec 21, 2015 | Thermador Kitchen Ranges
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
I used the dryer last night with no issue. When I went to use it this morning, I pressed the start button, I heard the motor run, but the drun did not move. After a second, the motor stopped trying. ...
i would say the belt that turns drum is broke,slipping or jumped off motor.try running without clothes in it.if drum dosent turn belt is broke or off
Oct 22, 2013 | Electrolux EIED55H Dryer
Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Sep 03, 2012 | Thermador CVS236 36" Cook 'n' Vent System...
Dryer was squeaking and now it just clicks when you push the start button
if motor will not run. check it out! it may be seized or in need of oil on end bearings. ( each end of motor ) just get access to the motor.
Feb 01, 2012 | GE Dryers
Window doesnt raise when pushing button off track
Regulator --common on GM ---sometimes spread to all the windows over time --albeit no warning
---honk honk honk come out window gone attempted break in NO ---the window dropped in the
middle of the night ---Silly ---laugh you bought GM --Ford's No Better
Apr 07, 2009 | 2002 Jeep Liberty
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
Thermador downdraft does not stop going up and going down automatically
I had a similar issue with the Thermador CVS30R hood continually going up and down, and also issues with the fan starting.
The issue was found to be a loose control arm off the motor. The arm itself moved outward on the motor shaft which resulted in it missing the switches that control the hood up/down and fan start.
This was a somewhat simple fix. Make sure the hood is in the down position. Unplug the unit from power(important!). Unscrew the screw that connects the drive arm to the drive link. Unscrew the motor/control cover, then unscrew the 4 screws holding the complete motor/control unit on (2 Phillips-head screw on each end of the assembly). Pull the complete motor/control assembly out, be careful of wiring. Once out, push the drive arm on firmly onto the motor assembly and tighten the screw. When doing so make sure the 2 micro switch arms are not caught and are free to switch.
When placing the unit back in, ensure all wiring is clear from being caught and ground is reconnected. Put it all back together and done!
I found this link to be useful for a parts/configuration diagram:http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232629&diagram_id=194441#d194441
Jun 05, 2007 | Thermador CVS30R Kitchen Hood
Kitchen Ranges Logo
346 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
