The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
I'm not sure I understand your question but, if you have an external DVD player, they probably will not work with it because you can't hook to the speakers directly. On the other hand, if you have a DVD player in your PC and your PC is capable, you can play DVD's through your PC. You may need software and if you want to play Bluray, you would need a Bluray player for your PC that, you may be able to add if your PC has an empty slotor, you could purchase an external USB player which will do either. Please clarify what you are trying to do. Thanks, Dave
I'm not familiar with a KX-T6160 system, so do you mean SIX-SIXTEEN-DEE(616d) or SIX-SIXTEEN-TEN (61610)? Either way, the cordless phone works. You need access codes, like 9 for an outside line, FLASH and dial an extension for transfer, 40 for ringing call pickup (on the 61610), and 58x (61610) to pick a line from hold. Your phone system manual has a single line telephone user guide in it.
YOU Go through the manual or if the manual is misplace download another from Google site you will type it like this t6160 creative speakers how to connect the dvd it will take you to the site then download it from there
Hi all, I also purchased a logitech x-540 a few days ago and also have
the center speaker outputting sound when i test or play the subwoofer.
I didn't think this is normal and am now confused. Maybe its a problem
with the audio drivers? MB is a ASUS P6T Deluxe V2 with Soundmax
drivers. Hopefully someone can help to diagnose/ find a soluytion.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
