Question about Panasonic SV-MP510 MP3 Player
Help me how to put music to panasonic sv-mp730v
I have panasonic sv-mp730v it cant upload so let me know it just charging when I put to the usb port
  • Anonymous Jan 25, 2008
    I have the same problem, an solution
I just bought this mp3 player by delstar. it's a ds 1700 series. and i don't know how to go about downloading music on here..
Posted on Oct 12, 2008
Old croc,
all you need to do is to give the battery a "boost" - I had a NiCad 1.2V charger lying around and just charged it up for 5 minutes with that and then when I plugged it back onto the charger - away it went again.
One the battery is charged and you can turn it on, that is when you plug in the USB cable and then the drivers for Win XP load and away you go.
Posted on May 02, 2008
When the battery is charged it should appear as a USB storage device to your operating system.  You can interrupt the charging by pressing the `mode' button if your battery is good.
I found with my (SV-MP730V) that with a duff battery, I got the symptoms you describe ... now I have to find a new battery!
Posted on Apr 11, 2008
SOURCE:
I have a panasonic SV-SD350V.I connect him to pc to insert mp3 music.The pc show me that the music is inserted but when i turn the panasonic SV-SD350V on is telling me that NO TRACK.Why?Why i can't put the...
The music player needs a dedicated software in order to function properly. It is called 'SD-Jukebox'. Download the zip file from the link below, extract it and run 'setup' file to install SD-Jukebox to your computer. Here is the link:
https://drive.google.com/file/d/0B-CDlRvR1Z_gWnlkdWlDSlBZSGM/view?usp=sharing
Have fun.
Nov 14, 2010 | Panasonic SV-SD350V MP3 Player
How do i upload pictures from the panasonic sv-av20
According to this description on Amazon, your model uses SD memory cards:
http://www.amazon.com/Panasonic-SVAV20-Digital-Camcorder-Camera/dp/B00008OLBN
Then you should have 2 options:
(1) The easiest is to remove the SD memory card from the SV-AV20 and insert it into an SD card reader (many available, starting from below $10). The SD card reader will have a USB connector so you can plug it into a USB port on your computer. Your computer (Windows or Mac) should recognize that you've inserted this and show the data on the SD card as a removable storage device.
(2) Clunkier option is to use the USB cable that typically comes with digital cameras -- these require the camera to be turned on. If you're unlucky, you may have to install camera-specific software on your computer to recognize the device. Since I hate adding extra software to my computer, I far prefer option #1 above, which works universally.
Hope this helps.
Aug 13, 2009 | Panasonic Cameras
Panasonic SV-MP730V
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Aug 28, 2008 | Panasonic SV-MP35 256 MB MP3 Player
What is the connector on the SV-AS10 camera?
you can get a lenmar CLIP battery charger that works through USB to just charge the battery.
you can charge a lot of other batteries too but you will need to use the docking to upload your pics to PC or use a card reader.
Jul 18, 2008 | Panasonic SV-AS10 Digital Camera
Where to buy Battery for SV-MP730V???
hi, i'm not sure where you're from but i just bought the battery at sim lim square in singapore for the model SV-MP730V (Penasonic). they have a website to it, you may want to look it up to see if there is any near your place
website: http://www.battery.com.sg
email: [email protected]
Apr 11, 2008 | Panasonic SV-MP510 MP3 Player
Won't Upload Songs
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
Nov 02, 2007 | Panasonic SV-MP020 MP3 Player
Computer won´t recognize my player
format the player from the player ( set-system menu) not from the computer. pull the battery from the player and leave it out for 15 minutes.
reboot your computer. put the battery back in the player.
plug it into the usb port on the computer. worked for me
Oct 19, 2007 | Panasonic SV-MP020 MP3 Player
Need to upload music in my panasonic sv-mp730v
you don't need any software. You only have to put the device on and then plug it to the usb port then it will have an usb connetion and you can put your files in the player.
test my site: www.pioneerspunch.de.tl www.urban-world.de.tl
Oct 03, 2007 | Panasonic SV-MP35 256 MB MP3 Player
Protected
Sounds like you have bought protected music that will only play on your computer. There are a couple of companies that do this with the music that you buy from them. goto the music file that you are trying to upload to your MP3 player, right click on it, and choose "properties". at the top, there are 3 tabs, you'll only want to pay attention to "summary" look down in the "origin" category...is it protected? If it is, then this is why your MP3 player isn't playing it. It will only play on your PC.
Apr 04, 2007 | Panasonic SV-MP020 MP3 Player
Charging but can't upload
Just remove software installed on your pc and install it again
Feb 10, 2007 | Panasonic SV-MP35 256 MB MP3 Player
Panasonic SV-MP510 MP3 Player Logo
231 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
