Question about Dell Inspiron 8600 Notebook
Lines on screen
I have a Dell Inspiron 8600. Just a week ago, I noticed a random purple line going vertically down the screen, it appears over everything (browsers and so on). I didn't think much of it, until a yellow line showed up. Now there are six lines, from purple to yellow. They're thin lines, so I can still see what I'm doing, but I'm afraid that they will eventually fill the screen. How can I fix this?
  • 3 more comments
  • Anonymous Nov 12, 2007
    I have a Dell Inspiron 9600 notebook. Same thing, colored vertical lines on the screen. Dell and other websites say its an LCD problem and has to be replaced. It can be as much as $500 bucks! I don't know why this doesn't get the press that bad batteries and bad chips get.
  • KenCJ May 21, 2008
    I also have a Dell Inspiron 8600, and I have a single blue, green and red vertical line running down the middle of the screen. I hope someone has a solution, because the computer works fine otherwise. I thought it may be a software problem, or a connection problem. Any help would be appreciated.
  • Anonymous Nov 16, 2008
    Mty dell 9300 developed a single blue line about a month ago. It's pretty old now (3/12 years) and has seen a lot of action, so I wasn't all that worried. Since then, however, another blue line and now a green one have appeared. Reading the forums on the issue, it seems it's only a matter of time before they multiply enough to block the screen.
  • Anonymous Feb 24, 2009
    Have a Dell Inspiron 9300, same multi-colored lines. Five of them appeared over the hinges. One disappeared on its own, then was followed several days later by a new one- dead center on screen. I do not agree that this problem is caused by any software as I have added a second monitor and it remains free of lines. This is clearly a defective monitor, and Dell has acknowleged that defective monitors were prevalent from one particular supplier several years ago. It may be too late, however, to ask for a replacement.
  • Anonymous Apr 29, 2009
    i have the same problem but instead of a dell, i have a hp compaq nc8000, first it was just the blue line, and now it is a yellow on, any ideas, i have no warranty for it so i cant get it replaced atm
I realise that this fix may not work for everyone, but it seemed to do the job for me...
Every time one of these glowing vertical running lines appear, I pinch the LCD surface gently to the plastic backing of the lid and then as gently lift it up and outwards... I apologise if the directions are not all that clear... How better can I describe it? Ahh, I jiggle the LCD within its plastic frame.
Whatever the reasons (contact points, loose cabling) this always fixes the problem, and I don't see it again for days / weeks.
Give it a shot!
Posted on Dec 27, 2008
My inspiron 9200 had black lines going down the screen the summer of 2007. eventually the lines got thicker and started to block my ability to read anything.
luckily I extended the warranty and the result was that the whole screen was swapped out in October of 2007. the bad news is it happened again -- just today, a little blue line just appeared. here we go again, not even a year with this new screen.
Posted on Sep 13, 2008
  • 661 Answers
This is a fault with the TFT display controller, Unfortunately this kind of fault is not User Serviceable, If this item is within manufacturer's warranty send it back and they should fix it for you, (REMEMBER TO BACK UP YOUR DATA as they may choose just to replace the whole thing)
Posted on Oct 03, 2007
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
Trying to determine if the video card in my Dell Inspiron 8600 is bad. The screen has is distorted with small discolored lines that are constantly on the display. There is also a bluish tint to the entire...
Ya seems like a hardware issue.. So tyr to run a hardware diagnostics on the laptop and see if it a hardware failure
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
Dec 07, 2010 | Dell Inspiron 8600 Notebook
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
Vertical lines on my lcd laptop screen
It's the connector problems.
If you know what to do, I can guide you:
First, remove the screw all over the LCD case, then you can see the connector, and flexible cables.
Second, remove the keyboard unit(by removing all screw on the unit), after removed, find the edge of the LCD cables, then you can see the connector.
The solution:
1.Try clean this two connector with soft brushes ( paint brush is good ), by removing the cable first,then clean the flexible connector using wet tissue ( use the alcohol ).
2. If still exist, you need to replace the flexible with new ones.
Feb 26, 2010 | Dell Inspiron 6400 Notebook
Vertical lines have appeared on sony vaio laptop screen
If the liens are coming during Dell logo also means the screen is going.
If these are visible when OS boots up then reinstallation of graphics driver will solve the issue.
Thanks
Jan 01, 2010 | Dell Inspiron 9400 Notebook
Vertical lines appear permanently on the screen
your display is going out you can contact Dell for a replacement.
Nov 01, 2009 | Dell Inspiron 2200 Notebook
Vertical purple lines appear when watching tv but not dvd
You unit should be under warranty. contact the manufacture for the nearest authorized servicer.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Many times over years of use the thin canle that connects motherboard to monitor becomes loose very slightly but enough to create these type effects on screen.First easy test would simply be hooking up another monitor to rule out video card.Next would be looking up how to disassemble the plastic trim to expose the lcd cable then carefully disconnecting it then reseating it.If problem still exists wiggle the lcd cable see if it affects lines on lcd display if so then you probably need new cable if not then most likely an lcd screen.
Screens can usually be replaced in about 45 minutes by avg.person.
Feb 13, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 8600 Notebook Logo
457 people viewed this question
Clive
Clive
Alun Cox
