Home | Acer | Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-... | Blue Screen
Acer Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-57 / 1.9 GHz - RAM 2 GB - HDD 120 GB - DVD±RW (±R D... PC Notebook
Problem for Acer Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-57 / 1.9...
Blue Screen
By angels94 on May 01, 2009
Tried to update drivers. While updating .... I got a blue screen with a crash dump. Laptop shutdown and restarted. I chose the start windows in safe mode to check things out. I only saw one driver problem. Restarted laptop. It's moving slowly. Could memory be an issue? I've never upgraded the memory.
Comments:
May 01, 2009
- I've ordered two Patriot 2GB 200-Pin DDR2 SO-DIMM DDR2 667 (PC2 5300) Laptop Memory chips and will install them as soon as I get them. Thank you for such fast response. I will let you know if this solves the issue.
May 07, 2009
- k... here we go... before I could get the new chips installed ... the laptop crashed again and this time it will not boot. I get the Acer screen with the F2 option to go into BIOS but nothing else. It comes up to a blank screen with the blinking cursor in the top upper lefthand corner. Tried a manual boot and operating system is not found. I went ahead and installed the new chips. Looks like I might need a recovery disk from Acer unless there is a way around that. I tried the Alt F10 function and that failed as well.
May 07, 2009
Jun 20, 2009
- I installed a new hard drive and upgraded the ram. Laptop is working perfectly now with the exception of my wireless problem (still working on that). The old hard drive would not allow boot with old and new ram. It would not boot even with the system cd. So, the new hard drive was the trick. Thanks.
Clarification Request
Posted by zohail on May 08, 2009
u can try installing the OS but if the OS recovery files in ur safe partition was affected and u are unable to restore OS from them then it is a possible Hard Disk Failure and for the recovery later on u need Recovery Disk from Acer u can order them they will send u mail for the recovery disk
but u need to buy a new hard drive , First u can try installing OS from Recovery disk u get from Acer if it doesnt help u shud buy a new hard drive , its failure is much frequent, these days bcoz of jerks and bumps its a daily wear and tear
but i am now sure in my solution
Posted by zohail on May 01, 2009
ok please let me know about this i can help u more in this please see that these Rams shud match ur specs
look it may be RAM problem pls try removing one chip if u have 2 insttalled or get a new one with same specs for testing these Blue Screens are 100% Ram problems
Solution #1
posted on May 15, 2009
Somewhat Helpful)
vortash
Rank: Guru
Rating: 88%, 234 votes
Hi I am vortash .. if I may suggest that the cmos has registered the old ram and you havent saved the new one to the configuration yet and on top of the problem you had the computer is finding it hard to comply with conflicting data , Put your old ram back in and ree boot
once or IF the bios screen becomes available press defaults on all systems and rebboot .. if you have a system recovery disk now would be a good time to insert it .. allow the windows disk to recover your hd and after your system is working again then place in your new ram depending on the age of your laptop systems now are not so dependant on paired ram but should you have the older set up I am afraid you will need a matched pair to effect a boot . If you check in your bios on the first boot in the advanced configuration should be a setting marked memory parity turn it off or ie disable it and the new ram will be accepted paired or not ... hope this helps regards Vortash
Was this helpful?
Yes
No
Solution #2
posted on Jun 22, 2009
Very Helpful)
zohail
Rank: Guru  Acer Expert
Rating: 92%, 1061 votes
pls rate me WELL if i have helped u !
Regards
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Acer Aspire 4520-5141
Questions and Unsolved Problems for Acer Aspire 4520-5141
Do you recommend Acer Aspire 4520-5141 -Dual-Core Athlon 64 X2 TK-57 / 1.9 GHz - RAM 2 GB - HDD 120 GB - DVD±RW (±R D... PC Notebook?
Answer
Answer
Please I need help I have a laptop bios password omnibook XE3 with the key and I need the hashcode... (More)
Answer
i need a recovery cd for a m100 toshiba satellite i live in NZ, Pukekohe, Auckland
Answer
how to replace a compaq evo 900US DC power jack
Answer
Have a EASYNOTE E2560 but it freezes on packard bell screen when loading.
Answer
hi my intergrated web cam will work with the cyberlink software but when i go onto webistes which... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 4520-5141...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
