Question about Umax Astra 1220P Flatbed Scanner
Yellow lines when I scan anything, I get yellow lines down the sides of the document. If it goes to the printer or to an application, I get the stripes of yellow. Is there a fix or download? Thank you onion129
    Genius:
  • 1,601 Answers
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
Why are there black lines down the centre of my faxes
This can be due to some dust on the scanning apparatus. Simply try blowing it out. If it will not help, it is probably defective, however it rarely fails completely. On scanners it sometimes does yellow stripes. It usually comes with older devices.
Apr 14, 2010 | HP OfficeJet 6310 All-in-One Printer...
Red/yellow line down left side of document when using feeder
the solution to this issue is cleaning the scanner glass below the automatic document feeder(mind you its not the scan bed that you normally use while copying) .you will get the ADF scnner glass once you lift the ADF door,you will see a 1 inch wide scanner glass.that is what you need to clean.
If you want any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jun 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Black stripe down center of document
as you have cleaned the scanner glass..try these steps..
1)connect the printer to the wall outlet..
2)then try to make a copy..if you get lines..then go to next step..
3)unplug the power chord..press and hold OK and CANCEL button together..while pressing the buttons plug in the power chord..
4)after you plug in the power chord do not release the button till the screen goes blank..once its blank release the buttons and then turn on the printer..
5)try to make a copy..its still the same..it is a hardware issue..machine should be replaced
6)Call HP who would give u a rebate on old printer & replace it with brand new printer.
Mar 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Yellow lines
It sounds like you have a corrupted scanner driver . Please uninstall and reinstall.
Here are the drivers
http://support.microtek.com/product_dtl_2.phtml?prod_id=5
Nov 10, 2007 | Microtek 3630 ScanMaker Scanner
Umax Astra 1220P Flatbed Scanner Logo
456 people viewed this question
Top Umax Office Equipment & Supplies Experts
Alun Cox
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
