Solve my problem
My washing machine only take & drain water and finished the full circle But nothing moveing and do not spin at all,so i have put a pairs of new brush and clean the filter as well,still the same,could you resolve this problem please
  • 209 Answers
You are in the right area, the motor or the motor control circuit board is the problem (assuming you have checked the drive belt) check the control board for any blown or burn marks, sometimes when motor carbons wear out they can damage the board, have you connected everything back correctly and fitted the carbon brushes right, double check you have done so, easy mistake to do keep going you are nearly there
Posted on Oct 04, 2007
SOURCE:
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
Washing machine won't spin
It sometime appens that the program was not finished let it do a full program with nothing in it
Jan 26, 2018 | Washing Machines
Just finished washing a load and putting in dryer when I noticed the clothes were still wet. The tub was drained just not spun very well. So, I set the dial to spin and heard a motor noise but no...
hello, it sounds like to me that your clutch is going out on u and mos tlikely did . this means u may or will have to replace the motor or just pick up a used one or new one .
hope that helps.
good luck.
thanks.
veronica gillespie
May 06, 2011 | Washing Machines
WATER NOT DRAIN OUT, MACHINE NOT MOVE TO THE NEXT STEP AFTER WASH, NOT RISING, NOT SPIN NOT COMPLETE THE FULL CIRCLE... CAN IT BE FIT PLEASE & HOW?
first check the drain on the washing machine to be sure it is not clogged. if not then the problem could be your pressure switch. if you have a multimeter use it to check for any electrical issues. if there is no reading the pressure switch needs to be replaced.
Feb 04, 2011 | Whirlpool Washing Machines
I have a Hoover 750L washing machine and it is not spinning now in the washing circle so the clothes are soaky wet. How can I fix this problem
is this not spinning due to not pumping out water/..if so clean drain pump/check filter.this should fix
Mar 31, 2010 | Washing Machines
Water not spinning out. clothes still wet when finished spinning.
check that you have water going down the machine drain pipe when the machine would normally be draining, if not could be a faulty water pump or a water pump blockage the machine is spinning whilst still full of water I am suprised you can open the door after the wash has completed
Jan 16, 2010 | Washing Machines
My washer stops after the wash cycle. not draning or spinning
CHECK THE RUBBER DRIVE BELT FOR THE PUMP UNDER THE WASHING MACHINE
May 09, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
