Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC 56 I have a JVC 56" rear projection TV and one day when the tv was turned on extremly to loud from the kids i shut it off then when i turned it back on the whole picture has a redness throughout and like a double on the picture screen. someone said this can be adjusted in the back if you take it apart and adjusted the color tubes. any ideas for this problem. i dont have 750.00 for someone to come out and fix this by replacing a part that may not be needed. thanks
  • 2 more comments
  • LON916 Oct 03, 2007
    HERE IS WHAT MY TV LOOKS LIKE IF THAT HELPS.
  • LON916 Oct 07, 2007
    THANKS FOR THAT BUT I AM NOT SURE WHERE THE MANUAL IS AT THIS TIME AND IS THERE ANOTHER WAY TO ACCESS THIS OR DO I NEED TO BUY A MANUAL SOMEWHERE - THANKS - LONNA
  • broo3369 Nov 11, 2007
    I'm haveing the same problem but when i try to adjust the convergent lines, the red does not move in any direction. the green is the stationary one.
    Also, the red is curved in on the top and bottom of the screen.
  • Anonymous Apr 10, 2009
    Convergance problem I paid $300.00 to fix! If you have any chance you need to go to menu then select convergance then manual then select on remote to change color then on remote select 2,4,6,8 to change quadrant on screen to move red or blue you use the channle/remote buttons in your remote to move red lines L-R-up-down to adjust, If you cannot fix with this method you need to replace defective parts which service man told me were junk and were made to fail "GOOD LUCH
    Genius:
  • 1,153 Answers
Look in manuel for convergence setting and reset. This happens if your set has been moved lately or shaken adbruptly.
Posted on Oct 03, 2007
  • Lashawn Robinson Oct 08, 2007
    Try menu and look for settings and find convergence and you can read what to do. Hope this helps!
SOURCE:
Tv keeps shutting off
lamp might needs to be change if not check to see if cord is all the way in back of tv and wall
Apr 23, 2013 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
TV Has no pitcher
you could have a shorted tube Green disconnect CRT board from green tube if set stays on tube is shorted also check video ic on crt board.
Dec 07, 2008 | JVC AV-56WP74 56" Rear Projection...
My JVC tv Is in digital and i want it in Analog
Look to see if your remote has a button with A/D on it. That is the button to press to switch back and forth between the analog and digital tuners.
Mar 28, 2008 | JVC HD-56G886 56" Rear Projection HDTV
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
130 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
