Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
The Bissell 79011 is not releasing cleansing formula
  • 2 more comments
  • tl_shinault1 Aug 10, 2008
    The cap to my soap dispenser has never fit tightly and at times released all the cleanser onto my floor. Now I cannot get any water to dispense onto the floor. (My livingroom rug seems to be ruined as a result the all the cleanser being dispensed all at once).
  • tahoejuli Aug 18, 2008
    Machine suddenly stopped releasing cleaning solution. It won't dispense any while using the upholstery attachment or the floor cleaner.
  • spiffster71 Sep 22, 2008
    Water/solution comes out of hand unit but not bottom unit. Suction works on bottom part but no liquid comes out.
  • pizza pie Oct 22, 2008
    I have the same problem, yet the plunger on the soap dispenser opens fine.
    I get solution from the hand held, suction but no solution on the bottom. I am sure the directional flap is positioned correctly as well.
    Problem Solver:
  • 9 Answers
I Had the same problem with my model 79011...take the upright handle apart
Posted on Sep 13, 2010
    President:
  • 1,673 Answers
Check the nozzle at the bottom of the soap dispensor, is the seal on it? and can you push the plunger so that it opens up, other wise replace the cap and vavle asm part # 2101795 .
Posted on Jan 17, 2008
SOURCE:
No soap coming out on my bissellproheat2X pet
Sorry to hear your ProHeat 2X isn't releasing formula. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1131&cid=ccsocial
Dec 28, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
How do you put the soultion in and how do you use it
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Apr 06, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
How much soap to use in the model 1770
Half a capful per tank of water. Make sure you use the BISSELL 3X Concentrated Fiber Cleansing Formula made for the machine.
See below for the manual.
http://www.bissell.com/assets/0/132/134/228/9367721b-1131-4a4c-b8fc-a7ceef5728e4.pdf
Mar 03, 2011 | Bissell 1770 QuickSteamer Upright Vacuum
I have a Bissell Proheat 2x cleaner which has worked perfectly on every occasion. Today I filled the machine as usual with water and formula and switched on, the motor ran, the lights were on and the...
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Using Bissel proheat carpet shampooer. Have used
No, you don't dilute it. And yes, it does use a lot of formula!
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
Note: Remember to secure the lid and test to
make sure it is secure before picking up the Tank.
6.
Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Quicksteamer
Below is link to the directions for use for your vacuum: http://www.bissell.com/images/UserGuides/2070.pdf Just download to your computer and view with a pdf viewer or print it. Good luck.
Jun 13, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
168 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
