After purchasing a panasonic blu ray player i bought an HDMI cable to maximise picture and sound. Unfortunately i can't find the input channel for the connection....i have 6...but none seem to locate it! I have a Sony Bravia tv. If you could please help with a solution to the problem it would be much appreciated.....i know it's probably something simple.
cheers
Jeff Winslow
Hello Jeff. I just have a basic question for you. Was the Blu Ray player turned on when you first plugged it into the tv? TV's are becoming so complicated that they are becoming less user friendly. Try setting your tv to the first HDMI input using your tv remote's input button. Then unplug the HDMI cable from the tv, make sure the player is turned on then plug the HDMI cable into the left most input if horizontal or top input if vertical. Hopefully if you do that and have the input selected, it should work for you.
Also: Whi9le attaching the cable, I find it helpful to have it in a position where I can see the tv, because when a device hooks up the screen usually flashes or turns blue or something similar.
Hope this helped
-Chris
