Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Red color abunDANT
MY TOSHIBA WIDESCREEN IS 46 IN. HAS A DARK RED/PINK TINT TO IT .SAYS TOUCH FOCUS ERROR WHEN RUN.
  • davef33 Mar 15, 2008
    I get a separation of color at the bottom of the screen,along with a "wavy" banding in the same area. Using the auto-sync feature produces the same error as the original poster. When I try to manually adjust the sync (using the numbered grid it displays) the blue "cross" won't move back in sync.
    Genius:
  • 1,694 Answers
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Posted on Oct 04, 2007
  • Vista Electronics Nov 05, 2007
    Please verify model # from back of set sticker......T.
MY TV HAS A DARK RED/PINK TINT TP IT. IT W THE PICTURE ON YHE SCREEN.
Posted on Aug 18, 2009
6ya staff
SOURCE:
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
46 toshiba plasma has red tint in back ground
If you can see the red tint with every input source and also in the On-Screen Menu, then this indicates that the Green phosphor is burning off of the screen faster than the Red and Blue. This is typical of plasma screens. Even if you dont watch a lot of golf or football, green is the most dominent color and burns out of the phosphur pits(pixels) faster than the Red and Blue. Take away green, you are left with Reddish looking screen and Pink whites. This is not repairable.
If the Menu looks nice and white, check your source cables.
Good luck
Dec 30, 2009 | Toshiba Televison & Video
Toshiba problem!
Your Convergence IC's need replaced. I recommend calling a service company if you want to invest in the repair. Most shops charge anywhere between $250-350.
Jun 23, 2009 | Toshiba 42HDX82 42" Rear Projection...
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
57H81 Red Bleeds, Dull Color, Was Pink
change the l.c.d colour corretion board new £ 400 not worth doing in my opinion part hard to get i stopped reparing these 5 years ago . agro agro agro ebay part not good these sets have a horrible short life
Dec 08, 2008 | Toshiba 57H81 57" Rear Projection...
LP70+ projects a dark rose/pink tint upon the screen
The pink tint produced by my LP70+ projector was not a lamp issue but a connectivity issue. I swapped the old cable with a good known cable and the tint went away.
Aug 14, 2008 | InFocus LP70+ Multimedia Projector
Red tint makes a double picture
Need to replace the two STK392-110 Covergence ICs. You can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jul 14, 2008 | Toshiba 43HX71 43" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Pink tint when shhoting in bright sunlight
Sane problem with C713, the view screen is dark and gives focus warning, then the pics come out with a pink tint. I believe it is the sensor or shutter problem. Can't get any solutions either.
Nov 12, 2007 | Kodak EasyShare CX7530 Digital Camera
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
234 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
