Question about HP OfficeJet 6210 All-In-One InkJet Printer
AutoFeeder Copy with Lines
Whenever I make copies using the autofeeder, the copies (as well as faxes) come out with a line across it. It has something to do with the feeder bc when I make a single copy lifting the lid, using the scanner, there is no line. Any thoughts, suggestions, solutions?
  • steffer Oct 04, 2007
    It's Fixed! Thanks!
  • 45 Answers
TRY FOLLOWING THIS LINK http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=421991&dlc=en&lang=en
Posted on Oct 04, 2007
SOURCE:
Blank lines across fax
blank lines across fax: if you get it when receive its from the sender but if when you send or make a copy you should clean properly the scanner unit with alcohol and cotton, its the trace of corrector liquid
Oct 12, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
2 lines are going down the page when we send a fax. The recipient is stating that it shows up on every fax sent from our 7440N Brother.
If you are using the Auto feed tray (feed paper in on the top), check the small glass panel on the left side of the machine, there may be small spot of white out or lint or dust. This has been the cause of most of our lines. If you are not using the autofeeder than you may have some internal scanner problem. I would see if there is a firmware update by going to brothers website and downloading the most recent updates to the firmware. The link to the firmware download page is: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7440n_all
Jul 12, 2010 | Brother MFC-7440N Laser Printer
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Lines on copy/scan/fax
You have something on your "scanner glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
Aug 04, 2009 | HP Office Equipment & Supplies
Vertical black line on side of copies only when using autofeed
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Apr 11, 2009 | Canon Office Equipment & Supplies
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Black line when aoto fed document prints
If you lift up or open the auto feed you should gain access to a small **** glass underneath the autofeeder. Clean that glass with alcohol or some other glass cleaner. That should clear this up.
If any debris get on that glass the result is dark lines caused when the page travels over that part of the glass. Hope this helps. Let me know.
Nov 25, 2008 | HP Office Equipment & Supplies
I have lines through all my scans all of a sudden
If you lift up or open the auto feed you should gain access to a small sliver of glass underneath the autofeeder. Clean that glass with alcohol or some other glass cleaner. That should clear this up.
Nov 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Getting a black line on the coppied paper
Nov 25, 2008 | Xerox WorkCentre M123 Copier
HP OfficeJet 6210 All-In-One InkJet Printer Logo
115 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
