I recently formatted my PC with Windows XP SP2, but I've had a little problem on the sound card. I got all functioning (graphics, internet, ...) but the sound card doesn't seem to work properly. I went to HP's site (my model is a HP Compaq Dc5100) and downloaded all drivers, but when I installed Soundmax program (which previously did work on my computer) it said 'driver not found - reinstall and run program again' or something like that. So, I went to Device Manager and it had a yellow question mark on 'Multimedia Audio Controller'. I've tried various times installing the driver but the outcome is always the same. I was wondering if anyone here could give me any help...For further details of the PC:
http://i41.tinypic.com/2urtob6.jpg
http://i41.tinypic.com/2v1aurt.png
Note: As I am from Portugal, some words in Belarc Advisor MAY BE in Portuguese.
Thanks in advance.
Comments:
May 01, 2009
- I'm sorry, I do have some PC CD's left, but none of them found the driver in it. :/
Open the Device Manager, click on the icon, which is marked with question mark, hit delete button then a prompt will pop-up then hit Yes. After a while or after Windows restart, it will prompt you that you need to install driver for a new hardware, I assume you still have the Drivers CD, which comes with your PC, dictate the PC to search driver from the CD or DVD drive. This should do the trick. if you still have further inquiries or if still this doesn't work, please post another thread.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq dc5100 Microtower PC
The clientpro 385 was recently restarted and now the power button flashes green every one to two...
(More)
The clientpro 385 was recently restarted and now the power button flashes green every one to two seconds. Unplugging the computer and plugging it back in changes nothing.
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the...
(More)
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the LED Toggle to light up, can this ground be connected to one of the computer 4 pin Molex Black wire. If so which one the Black Wire next to the Red Wire or the Yellow Wire.
computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store...
(More)
computer will not turn off, it just reboots. took it back to dealer and it worked fine at the store but as soon as I plugged it in at home office it didn't turn off
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of...
(More)
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of processors are compatible with the motherboard of this computer. Please help mE THANKS!
When I bought an older model Dell PC I was assured it came with cd burner... Whenever I insert a...
(More)
When I bought an older model Dell PC I was assured it came with cd burner... Whenever I insert a blank cd to burn material on my pc says "to insert disc" as though its not reading it. I've tried a few brands of blank discs and no luck. Im hoping theres a way to solve this problem on my own....
