Question about Frigidaire FSC23F7D Side by Side Refrigerator
Frigidair frs22zrf side by side w/ front ice and water
There is no water coming from the dispenser. The ice maker wasn't working either and I switched the connectors on the control valve at the bottom rear left if facing the front of the frig. And now the ice maker works so at least one of the valves appears to not be working. I took off the demand side of the water line at the double valve and tested each valve by swapping connectors and activating the door water dispenser. Only one valve responds by opening. does this mean the one valve is not working properly? So it appears that the valve that was working was originally feeding the door dispenser, but for some other reason no water is dispensing. what other possible reasons are there for not getting door water.
  • Anonymous Mar 24, 2014
    It's not working
I've been having the same problem, so I goggled the solution and followed many suggestions. I replace the one of the dual water inlet valve (218658000). This is the one on the left lower corner (if facing the front of the fridge). But it did not solve the problem. Then I found there was another dual water inlet valve on the right. This is the one that receives the water input. I found that one of valve (yellow color) rubber was stuck. You will have to disassemble the valve to see the inside of the valve. There is a spring and a round metal tube. There is also a plastic thing that will stop/allow water to go thru. The rubber appeared to be hardened so it got stuck with the housing. I replaced the stuck rubber piece and the water dispenser works perfectly. I appreciated so many people posted their solution. I hope mine will help others too!
Posted on Jul 11, 2010
The water dispenser on the front is working but the water will not deliver into the ice maker. We drained the lines and did everything possible to get the water to come into the ice maker. The ice maker is working but will not make ice.
Posted on Oct 20, 2008
  • 290 Answers
From what you are describing, it sounds like you need a valve. Another common thing I run into is the cooling tank inside the fridge freezing. This will usually affect water through the door only. Remove the crispers and you should see a large coil of plastic water line attached to the back wall of fridge. You can check to see if it is frozen by blowing through it from the end of the line you removed from valve. BEWARE, if you blow through it, water will come out dispenser if line is not frozen. Have a towel at front of fridge.
Posted on Oct 03, 2007
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your refrigerator problem and see what you found wrong.
    Thanks/Mike
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
Frigidaire FRS23KF7AW2 Side by Side No water
I believe the water valve may sound like it is trying to open for the ice maker. The water valve has two sides on it for water dispenser and other side is for the ice maker. One side goes bad you just replace the water control valve. I will return with part numbers. Sea Breeze
Mar 18, 2010 | Frigidaire FRS23KF7AW Side by Side...
Side by side Frigidaire. The water dispenser
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the tube.. You can take the water line off the valve and watch to see if it drips.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 30, 2009 | Refrigerators
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
619 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
