Question about Texas Instruments TI-5045 SVC Calculator
Texas Instruments TI-5045 SV paper won't advance
Hi, My paper is not advancing. Any solutions ? Thanks, Gary
  • 4 more comments
  • thibobc Dec 30, 2007
    Paper often will not advance.
  • chefed Feb 06, 2008
    mine too. Paper advance button works fine but when entering figures and hitting + or - button, advance is only marginal. ??
  • Anonymous Jul 20, 2008
    Mine won't feed paper either
  • tim6v20 Sep 07, 2008
    THe paper feed is not workig. Otherwise the addig achine is fine. Can someoe help?
  • coffeevice Dec 19, 2008
    I havethe same problem. I am unable to get the paper to feed. There has never been paper in the machine. Today is the first time I tried to use it. Otherwise, everything else seems to be ok. TI 5045 SV
  • mike75568
    mike75568 Feb 19, 2013
    Mine neither. I took it apart and the rubber driving roller has swollen to the point that it is no longer firmly engaging the grooves on the white splined plastic shaft (with integral gear). It looks like I might be able to replace it with a piece of rubber vacuum line. Tricky...
  • 3 Answers
The foam on the feed roller is probably decayed/ soft. Which has caused the plastic gear that engages that drive gear to wear. If the gear is moved/ spaced over to pick up the 40% that isn't trashed - it'll feed.
I'm going to try to fix my Goodwill purchase anyway. Anything is better that the Canon piece of rubbish I have now. Mybe someone can tell Canon that a few months of use is not enough?
-Sano-
Posted on Dec 31, 2008
    New Friend:
  • 3 Answers
Crtlfreak - On mine the rubber roller sleeve, (mine is soft rubber not foam) expanded and is no longer firmly engaged to the splined plastic shaft which now just turns inside the rubber sleeve. I'm going to try a piece of vacuum line or other thin wall rubber tubing.
Posted on Feb 19, 2013
  • 2 more comments
  • mike75568
    mike75568 Apr 15, 2014
    Firgot to come back... I disassembled down to the splined shaft, removed the old rubber sleeve and slipped on a same length piece of silicone rubber tubing. Works PERFECTLY now!
  • mike75568
    The silicone tubing I used happened to be fuel line from my R/C airplane box. I probably got it from Tower Hobbies 10 years ago, either "Great Planes" or "Dubro" brand, I believe it was 1/16 ID and a thin wall. The shaft is bigger so the tubing stretches over the shaft and stays put.
  • mike75568
    Memory coming back .. It was a little tricky to get it on to shaft, you have to hold the new rubber tube piece in position at the cut out of the metal shaft mount then insert the shaft working it along until the shaft is inserted all the way. (You cannot put the piece on the shaft then insert it.)
  • Joseph Nafnlaus
    Joseph Nafnlaus May 02, 2014
    Hi Mike, How did you disassemble that thing. I have this problem and can't figure out how to get to the spindle. Any helpful info/pics would be greatly appreciated. Thanks!
SOURCE:
Can't load new roll of paper
The rubber sleeve on the paper advance shaft has likely lost it's elasticity. It expands then the shaft just spins inside of it. It's tricky but I disassembled the paper advance assembly and replaced the old sleeve with a piece of small silicone tubing. Works fine now.
Mar 31, 2014 | Texas Instruments TI-5045 SVC Calculator
Won't boot to desktop
Hi Cheryl,
If you've just recently installed anything, you can boot into safe mode and uninstall the offending software..
-Restart your computer and tap on the F8 key until you reach the Advanced Boot Options menu and select "Safe Mode"
Hope this helps,
Thanks!
Gary
Oct 17, 2013 | Gateway Computers & Internet
Cyberlink dvd error code 0012
Hi Sergi,
Go to settings > Blu Ray > Advanced > Allow Power DVD to automatically disable windows Aero to optimize Blu Ray Disc Playback
Hope this helps, Please Rate;)
Thanks,
Gary
Jul 15, 2013 | CyberLink Computers & Internet
How can i fix my paper jam on my epsom 1600, multi printer
Hi Gary, if you've done all this put off the printer and switch it on again. If it persists then a technician needs to open it.
Thanks.
Jun 28, 2012 | Office Equipment & Supplies
Texas Instruments TI-5045 SVC Calculator Logo
7,976 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
