I was printing several pages when my printer stopped, showing no black ink, even though the cartridge is more than half full. I took out the cartridge and reinstalled it but it still says no cartridge. I have tried 2 new cartridges, both OEM and non manufacturer product, but I still get the message to reinstall cartridge. How do I make the printer recognize that a cartridge is installed.
Comment by pinkcad, posted on Mar 23, 2008
When no simple solution appeared I took the printer in to a warranty repair depot and they replaced a part. Since then it has been working great. The thing that ticked me off was that I had to buy another printer to use while mine was in for repair. Since I had a large supply of 3rd party ink cartridges, I bought a second MFC 240 as they were on sale for about the same price as I'd pay for a complete set of Brother ink cartridges. Now that I have a back-up printers I probably will likely never have a problem again. I use generic ink and have been printing a lot of photos with good results and no problems.
My 4 in 1 Brother 240 MFC will not print. All colors said they were empty, one at a time. I have replaced them twice with no help. Brought the unit to a Computer repair store and they said I needed a sensor. I'd be better off getting another copier. What do you think? Could I replace the sensor?
N>D>
Yes! I just hooked up my brand new Brother Fax machine and it's not reading the Yellow in. Reading your post and realizing that I have to take the machine in for repair does not make me a happy camper.
Same problem here... Figured out something that works fine for me anyway.
I took some black electrical tape and covered the clear plastic area in the front of the cartridge. It's a bit of a delicate procedure. Need a piece of tape about 3/16 of an inch wide and 1/2 inch long to match the contour of the clear plastic so it still fits inside the printer and can be surrounded by the light sensors.
Unfortunately, I think Brother is making too much on the ink cartridges and therefore is trying to make them tamper proof. I t's backfiring on them. Will never buy another Brother.
Was this solution helpful? Show your Appreciation by rating it:
I do have the same prob. On my way to see the error clear, I first changed the carts to original ones, but no effect. Secondly I opened the printer and noticed, that ink had stained the inkcartridgebox (which must have been quite normal since the original cartridges stain the box, too). I have cleaned the hole box (and the inside of the printer, but had no success. So, at the moment, I am trying to change the inkcartridgebox to another (new) one. If this will be without success, it must be anothernew(!) - see error 30 and 50 which happens because of paperjam- prob of brother printers due to malfunction of firmware, since the machine displays this error (no ink) during print out of a 50 pages job.... (will post the result the next days)
Comment by Mix-it-up, posted on Oct 08, 2007
Still waiting for the sparepart. Hope to have it within the next week.
Comment by Mix-it-up, posted on Oct 23, 2007
Have changed the ink assy. Everythings working normal again.
The MFC keeps reading ink low and black ink empty. I install ink to no service. I restart the computer, and warped the phone line-just short of throwing it out the window, I think I have tried everything. Any new solutions? ________________ Aady Great Deals on Printer Ink Cartridges - Up to 65% Off HP, Espon, Lexmark, Dell, Canon and more. <a href="http://www.concordsupplies.com/ink-cartridges.html">Ink Cartridges</a>
Show your appreciation by commenting on MFC-240 shows no ink cartridge:
Solution #5
posted on Mar 22, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
I read that it uses light sensors to read the ink levels and a solution was posted to tape with dark tape where ink cartridge where the light sensor reads it and then you can use your ink till empty. I am disappointed in these Brother machines and expected better from them. Not being able to use black ink or print or fax or scan when a color ink goes empty is insane and Brother should have provided a firmware fix long ago for this problem. I will not be getting another Brother machine unless they do away with these problems in the future!
i have the same promblemm my cartridges are half full and it wont print and it tells me to change the cartridges and i have but it still wont reckonize and fix the problem.what can i do to solve this thank-you this printer is new havent had it long
yes, I have the same problem with MFC-240 printer says no ink, there was still ink in cartridge,but I still got a new one put in still said no ink and sometimes it said reinstall.
The MFC keeps reading ink low and black ink empty. I install ink to no avail. I shut it off, rebooted the computer, disconnected the phone line-just short of throwing it out the window, I think i have tried everything. any new solutions?
I am having same problem know. I have ink cartriges lc51 series, and i managed to put ink to them myself, they worked for the longest time fine . now i have the issue that it is not detecting the cartrige in the slot. it tellsme over and over again . no cartrige. you said something about waiting for an ink box. ?? what is that.
how do i fix this problem.
I have the same problem. It does not recognize the new cartridge or either the old one. Keeps on saying that please install the cartridge. The only catch is that I had recently updated the firmware. Maybe it is a firmware problem. But I cannot find any ways to rollback the firmware.
I have the same problem, no black ink cartridge showed in the middle of a print job. I have tried rebooting the printer and the pc. No luck. I have removed the cartridge several times and even tried a new one. Nothing is working. Very aggrivated. I homeschool and use my printer several times a day.
